Speed Sensor Bolt size?
Old May 7, 2013 | 03:57 PM
Tyson30's Avatar
Anyone know the size and thread pattern of the speed sensor bolt in the tranny, i need a new one cuz its leaking fluid cuz the bolt is stripped?
thanks
Old May 8, 2013 | 06:20 AM
onebadvert's Avatar
I believe its a 1/4 20 bolt short length maybe 3/4". But if it leaks doesnt mean you need the bolt. You probably can replace the sensor for around 35 $ or maybe even just the oring. I would clean off the seat area also to ensure a good seal.
Old May 8, 2013 | 09:40 AM
Tyson30's Avatar
thanks, im going to get a new sensor but the bolt is stripped and i cant tighten it down. im gonna try that size bolt
Old May 8, 2013 | 09:52 AM
onebadvert's Avatar
Ok. I could be wrong but im pretty sure thats its. Good luck man.
Old May 9, 2013 | 07:43 AM
conv_stang's Avatar
If the bolt is stripped, good chance the threads in the trans are damaged. Might want to run a tap down to clean it up
Old May 9, 2013 | 12:40 PM
Tyson30's Avatar
Very good idea, thank you for the input... I didnt even think of that
Old May 9, 2013 | 12:55 PM
conv_stang's Avatar
No problem man...hope it works out for you
Old May 9, 2013 | 06:50 PM
Tyson30's Avatar
how much fluid should i expect to come out when i remove the sensor?
Old May 10, 2013 | 04:05 AM
onebadvert's Avatar
I dont think any. It may though if you jack the front of the car up higher than the back,or if its overfilled. But you should be ok.
Old May 10, 2013 | 02:05 PM
conv_stang's Avatar
Shouldn't be much
Old May 10, 2013 | 02:33 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Your gonna need a helicoil... Just sayin
None
STOERKEL
Sep 11, 2015 11:38 AM
AMWill
Jul 20, 2015 08:40 AM
Jul 17, 2015 05:40 PM
