removing headrest??
1 Post
I took the ones out on my 05. Besides the side button on the right side of the headrest there is a pin hole clip on the left side. You need a paper clip to push into the pin hole to unlock the headrest while pushing on the side button at the same time and pull up at the same time. Hope this helps.
To remove them, there's this little tab up inside the seat that you have to pry loose with a screwdriver or something. Then you have to pull up really hard on the headrest. Here's a link that might help: http://www.musclemustangfastfords.co.../headrest.html
Antigini-GT/CS
10/5/15 09:43 AM
9/10/15 12:44 PM
