removing headrest??
Old Aug 31, 2008 | 10:01 PM
pony power's Avatar
removing headrest??
I have a 91 vert and want to change headrests anyone on this forum take out their's out or have seen it done any info would be great
Old Aug 31, 2008 | 10:45 PM
poldrv's Avatar
I took the ones out on my 05. Besides the side button on the right side of the headrest there is a pin hole clip on the left side. You need a paper clip to push into the pin hole to unlock the headrest while pushing on the side button at the same time and pull up at the same time. Hope this helps.
Old Aug 31, 2008 | 11:15 PM
Blue Notch's Avatar
To remove them, there's this little tab up inside the seat that you have to pry loose with a screwdriver or something. Then you have to pull up really hard on the headrest. Here's a link that might help: http://www.musclemustangfastfords.co.../headrest.html
Old Sep 1, 2008 | 09:08 AM
Valentino's Avatar
They are not the same as S197s, I found this at Stangnet quite a while back as this question is asked there at least once a week;
Old Sep 1, 2008 | 12:16 PM
pony power's Avatar
thanks I knew I could find this info here this site is the best
Antigini-GT/CS
Oct 5, 2015 09:43 AM
jim010
Sep 14, 2015 10:15 PM
Sep 10, 2015 12:44 PM
