Rear end gearing with C6
Old Oct 28, 2014 | 06:28 PM
Walterdurbin's Avatar
What would be a good combo 3.55, 3.73, 4.10 gears behind a C6 auto in a 92 Fox Body .... Go to drag race car engine is a 351 stroke R to 436cu. Extreme cam 1/8 mi. And some 1/4 mi.?
Old Oct 29, 2014 | 10:29 AM
HOSS429's Avatar
legacy Tms Member
how tall of rear tire are you planning to use ? ..
Old Oct 29, 2014 | 02:28 PM
I plan on using 28" M/T slicks
Old Oct 29, 2014 | 03:58 PM
HOSS429's Avatar
legacy Tms Member
it`s been a longtime since i`ve been to the drag strip .. if i remember correctly your optimum gearing would allow you to reach the finish line at the same rpm you make your shifts at ..for 1/8 mile blasts i always liked a 4;56 gear in my 429 tbird .. i would shift from first to second at 5500 rpm .. the 2nd to drive at 5500 rpm and reach the finish line at a bit under 5500 ..i had a 28 inch tire as well ..i dont remember my ET or speeds .. you mite be able to tote that tall a gear even for a full 1/4 with a high reving small block ..
Ecostang
Nov 3, 2022 08:50 PM
oilmanlee
Sep 10, 2015 07:33 PM
chadh92
Jul 29, 2015 06:56 AM
Kev006
Jul 8, 2015 05:29 AM
