Power Windows Failure
Old Dec 17, 2012 | 01:30 PM
LuvMy89GT's Avatar
Anyone have any advice on possible failure to power windows? I've replaced the master switch and relay in the fuse panel. I do hear a clicking sound when engaging the switch. One note: When I first bought the car I removed the after market car stereo an havent to date replaced it. Hard to say if this is related since the car wasnt driven (except from my garage to my shop a couple of times) over the last couple of months. You love links to wiring diagrams or troubleshooting guides, etc. if anyone has them. Thx.
Old Dec 17, 2012 | 02:21 PM
dcpirani's Avatar
The motor may be bad
Old Dec 17, 2012 | 02:44 PM
skunk21's Avatar
motors are known to fail but the wiring could be suspect. you can run direct power to it to run a test. here is the wiring diagram
Old Dec 17, 2012 | 02:46 PM
AlsCobra's Avatar
A Man Just Needs Some....
Test light and probe the back of the switch.2 leads go to each motor. 1 power, 1 ground depending on up or down. They change when pressed up or down. Test light to ground should light up each prong either up or down position. That's a good starting point.
Old Dec 17, 2012 | 04:28 PM
delz05's Avatar
One of the more common faults is a bad ground. Could be an under dash issue... check your ground circuit... if the window motor tests good.
Old Dec 18, 2012 | 01:10 AM
Skylar's Avatar
Could it be the fuse? My drivers side window stopped working and made the clicking noise when pressed. A couple months later it started working again. I'm still not sure what my problem was.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
RCooke08GT
Feb 19, 2017 03:03 AM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
