please pick out the flaws in my plans
Old Sep 3, 2005 | 04:54 PM
luvthe440Aroush's Avatar
ok i'm not exactly sure of what can be done so i want you to tell me if any of this cannot be done.
i want to buy a carbureted turn key engine
i want to pull the carburetor off and then throw and edelbrock EFI intake on, buy new fuel rail/injectors/pump
what kind of problem will i have to deal with if i do this?
by the way, i am starting with an EFI 5.0 engine in the car at the time i pull it to put the carbed engine in, i dont want carbed so i'm lloking for a way to turn a cheaper engine into its fuel injected version so i dont have to pay $2000 extra to get it with an intake i dont want anyway
Old Sep 3, 2005 | 11:16 PM
Valentino's Avatar
If the computer in the car is already from an EFI 5.0 I think you're good to go. I'm not aware of anything else that needs to be changed other than the fuel system and intake which you already mentioned. I'm not sure if the wiring harness matters or not... Don't forget the air intake tube and since your avatar says '87 GT I guess you don't need to worry about a mass air meter...
Again i'm not positive if thats all you need so lets wait for some more replies!
Old Sep 4, 2005 | 05:25 PM
MustangFanatic's Avatar
Let me see if I understand, you have a carb'd engine you can purchase to replace the current engine in your '87 GT? Unless you are getting a killer deal on the carb'd engine, consider buying a long block and simply swap the EFI set-up from the existing '87 engine. Let me know if I missed something and I'll try to provide some add'l details.
Old Sep 7, 2005 | 01:59 PM
i want to go with the turn key becuase its just that..a turn key and i get a really good deal on a brandnew serpentine belt system i dont know though, this is still in the future and i'm debating just throwing a 12psi procharger on i just kinna want the new engine for reliablitlity
Old Sep 8, 2005 | 09:55 AM
Andy Haynes's Avatar
Just a ? but why not just build your motor? You keep saying turn key but your going to have to swap all of your efi stuff over to it so its not exactly turn key . Then it kinda comes down to what all is done to that motor also . If it has been built with good heads and stuff then your looking at your intake and stuff starving the motor for more airflow. First thing you need to do is find out what is done to the motor. Then if it has heads or is built then you will need to look at changing the intake and also swap over to mass air and get rid of the speed density.
Old Sep 11, 2005 | 09:54 PM
i scratched that plan anyway, i'm gonna go with a long block, i'll give more details tomorrow
Old Sep 12, 2005 | 02:38 PM
poo, forgot about speed dens on the 87's...da*n it anyway i'm lookin at about 380 horse when i get done what size injector would you suggest with gt-40 heads and a trickflow intake?
Rando
Aug 25, 2021 11:12 AM
Autotooner
Nov 24, 2017 12:42 PM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
yabutt
Oct 23, 2015 01:05 PM
GeoWett
Sep 30, 2015 06:40 AM
