No tension on clutch fork
Old Oct 13, 2012 | 10:12 AM
88 coupe's Avatar
Help someone, have an 88 coupe used to be a four banger now has 94 cobra motor with a bunch of upgrades but still have four cyl tranny. Haven't driven it for awhile, get in clutch pedal goes all the way to floor , I check clutch fork and its going back an forth no resistance at all . Dhave to pull th
Old Oct 13, 2012 | 11:08 AM
skunk21's Avatar
could be a few issues. streched cable or snapped cable or the clutch fork is off throw out bearing or partially of it. the "forks" that slip over could be spread out and it isn't totally on the bearing sleeve. you should get a visual through the inspection cover. if turns out to be a bad fork ford racing sells an heavy duty one thru 50rest or other vendors. if it is the cable use a oem ford cable, aftermarkets do not last like the eom one. the aftermarkets tend to strech/break and make noise vs the oem but the oem does cost more ( price to pay for the longer life).
Old Oct 13, 2012 | 11:18 AM
1999Pony's Avatar
I second all this.
Gill5oh
Oct 6, 2017 10:50 PM
Sep 23, 2015 03:21 PM
JonathonK
Sep 19, 2015 03:19 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
