No power to the Fuel Pump
Old Sep 3, 2012 | 09:28 AM
swadsworth's Avatar
Wondering if someone can help me. Just rebuilt my motor. It is a 1987 LX 5.0ho. It didn't want to crank at first and the pump was not coming on so I changed the Fuel pump relay. Car started. Then it stopped after 10 mins or so. I think the fuel pump was turning off. Now The pump won"t come on at all. I changed the relay two more times thinking maybe I bought a bad one. No luck. I checked the power out of the relay. With the key on all the wires except for the pink/blk have power going out of the relay. Which is the wire going to the fuel pump itself. According to the Haynes wiring diagram the pnk/blk wire is a straight line from the relay to the pump. I checked the intertia switch and it has power on both wires. Any one have any ideas or toughts to help me troubleshoot why I am not getting power past the relay?
Old Sep 3, 2012 | 07:20 PM
onebadvert's Avatar
if the tfi module fails or isnt plugged in properly the the fuel pump wont get power.
Old Sep 3, 2012 | 08:07 PM
swadsworth's Avatar
Ok thanks I will check it out next.
Old Sep 7, 2012 | 03:46 PM
swadsworth's Avatar
Replaced it with no changed. Even cleaned the ground wires in the back for the pump and the gauge
Rando
Aug 25, 2021 11:12 AM
RCooke08GT
Feb 19, 2017 03:03 AM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
