need some carb help
Old Jul 13, 2008 | 11:30 PM
soitsav6's Avatar
need some carb help
when I bought the fox a few months ago I did a few quick maintenance things to help the running, one of the things was a rebuild kit on the stock Holley, since I dont drive the car much I haven't spent a lot of time with it, finally found today I had a gasket jacked up when I installed the carb back, replaced with no problem but I am still having one of the problems I had before rebuild. the carb seems to bleed down after the car sets for a while and after the reinstall today the throttle is sticking and I just cant figure it out, any carb gurus here maybe give me some advice? the throttle seems to stick after you get on it hard, you can hear what sounds like a bleed down when you turn the car off with the breather off. any help is appreciated.
anybody know a part number for a replacement Holley or Eldebrock? without modification to work
Old Jul 21, 2008 | 10:33 PM
soitsav6's Avatar
tons of views, no comments, found the sticking throttle problem, while tightning the bolts to the carb itself I inadvertly tightened the bracket for the a/c wot kill switch, it put the throttle in a bind, problem solved, am still working on what seems like a bleed off, did confirm not going back through fuel pump
MrSylphie
Aug 18, 2015 08:40 PM
luvthe440Aroush
Jul 14, 2005 09:33 PM
jes72mustang
Mar 28, 2005 06:54 PM
jes72mustang
Mar 24, 2005 07:10 PM
Jay
Oct 22, 2004 06:56 AM
