My 1990 Notch Project
#82
After the H/C/I my lil coupe is running STUPID rich...If I fire it up in the morning, go get my coffee and come back outside, it's like walking into a wall of fumes. I have an adjustable fuel pressure regulator on order, should be here next week some time. Anyway that won't do me any good if I don't have one of these. As expected 44 psi (vacuum off) So running fat....
Kit from LRS
![](https://sphotos.xx.fbcdn.net/hphotos-ash4/282807_447152315303606_2051741189_n.jpg)
Where it get's installed. This kit doesn't require you to remove the actual schrader valve out of the housing. The blue adapter has a nipple that actuates the schrader valve once you
screw it on:
![](https://sphotos.xx.fbcdn.net/hphotos-ash4/421493_447152411970263_1603721859_n.jpg)
About ready to install. had to put teflon tape on the gauge threads. BTW, in the instructions it tells you at least 3 times not to over-tighten the gauge or the fittings.
![](https://sphotos.xx.fbcdn.net/hphotos-ash3/526729_447152485303589_1087595169_n.jpg)
Installed. Sorry crappy camera phone :P
![](https://sphotos.xx.fbcdn.net/hphotos-snc6/208900_447152568636914_658853831_n.jpg)
![](https://sphotos.xx.fbcdn.net/hphotos-prn1/556550_447152655303572_1594220391_n.jpg)
Hopefully have it dialed in a bit more, get it back down to 39 psi where it supposed to be. Been going through fuel like crazy.
Kit from LRS
screw it on:
#84
Cool project! Helps me figure out what I want to do to mine. I post a pic of mine soon. I have already installed a MM suspension package under my car. It was pretty bad when I bought it. Looking to start on the engine now.
#85
Picked this up.. It finally showed up on last thursday. Just haven't had a chance to get it installed yet. REASON for the install is because the stock rag joint is hitting the downtube on the #5 longtube.
Anyway hopefully this will gain me the clearance that I need for the longtubes ![Smile](https://themustangsource.com/forums/images/smilies/smile.gif)
![](https://a1.sphotos.ak.fbcdn.net/hphotos-ak-snc7/411408_465897636762407_2088964751_o.jpg)
![](https://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/616305_466028630082641_284115721_o.jpg)
#88
Figured I'd take some pictures of the whole steering shaft issue. This is the reason I picked up the flaming river steering shaft:
Collapsible steering shaft that isn't so collapsible:
![](https://a1.sphotos.ak.fbcdn.net/hphotos-ak-snc7/412493_469890706363100_1237986262_o.jpg)
Yeah...soaking for the night:
![](https://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/473567_469890733029764_644538556_o.jpg)
The culprit:
![](https://sphotos-b.xx.fbcdn.net/hphotos-ash4/484435_469890756363095_1161572455_n.jpg)
Even with some clearenceing, it still hits:
![](https://sphotos-b.xx.fbcdn.net/hphotos-ash3/557893_469890779696426_458740962_n.jpg)
![](https://sphotos-b.xx.fbcdn.net/hphotos-ash3/555731_469890809696423_845876937_n.jpg)
The culprit:
#89
looking into a SCT 4 bank chip and a dyno tune. Wanna make sure I'm not running lean at WOT
Car was dyno'd prior to the HCI, which it made good power.
#91
Ohh okay I see I just picked up some gt40p heads aswell for about 95 dlls at a junk yard, so I'm about ready to start the same project.
I dynoed mine with the cobra Upper an lower intake, bbk cold air intake, tb, and mass air flow
And it dynoed at 230 hp and 270 tq.
Now hopefully I can port the hell out of these wads so I can be looking at around 2270-285 hp with the right cam
#93
A Man Just Needs Some....
Steering shaft looks good. How old are your motor mounts? When I did my headers, I ran into the same problem. Replaced the original smashed down mounts and it took care of things. Just wondering.
#94
#95
Wanted to do a little update:
About a week ago, while driving to work I noticed a bad vibration that kind of showed up pretty sudden. Brought the car home, and jacked it up. Figured it was maybe a u-joint. I've got a FRPP
aluminum driveshaft installed, that is fairly new however you never know. Well, as I got to the differential, and checking for radial and axial play, found that the differential pinon flange had a
ridiculous amount of play. Found my problem. Well this last weekend, I ended up down at Special Vehicle Operations (who's a very good friend of mine) who was kind enough to lend a helping hand
in helping me rebuild the rear axle. I had never torn into a rear axle (other than fluid change, and axle swap) so as far as setting up gears (backlash and preload) I was lost. Well my good buddy
gave me a really good understanding about tolerances and what not. Well as we pulled the rear end apart, we found that there were no shims installed between the carrier and the shims. You could
basically move the tapered shims back and forth inside the carrier. GREAT! As we dug deeper, we pulled the carrier out and proceeded to get the air tools out to punch the bearings off, one quick brrrrap!
and the bearings FELL OFF.....literally. We pulled the pinon gear out, to find that whoever previously set up the gears before me, never installed a crush sleeve, again bearings about fell off. Surprisingly
the gears didn't look bad. So after it was all said and done, rebuilt everything, and then even had some new goodies![Smile](https://themustangsource.com/forums/images/smilies/smile.gif)
Tearing it apart and finding missing parts (and yes that's a Terlingua in the background):
![](https://sphotos-b.xx.fbcdn.net/hphotos-prn1/621869_481885785163813_758224982_o.jpg)
Just about done:
![](https://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/202774_481886335163758_467096248_o.jpg)
a VERY VERY NICE piece of History (Indiana Jones of Foxbody stuff![Smile](https://themustangsource.com/forums/images/smilies/smile.gif)
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash3/s720x720/599310_477561625596008_1410718958_n.jpg)
So finished that all up. Then during the test drive and gear break in this happened:
NOTE, this was while pouring the coals to 2nd gear and snatching up 3rd with a Steeda Tri-Ax
![](https://sphotos-b.xx.fbcdn.net/hphotos-ash4/304556_477753185576852_789623872_n.jpg)
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash4/459306_481894658496259_879680293_o.jpg)
Then strangely enough these followed me home
Nice set of flo-fits
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash3/538642_477897702229067_2147108772_n.jpg)
That's all for now....
Just about done:
#98
It's called a Shelby Terlingua. Made by Shelby America. It has a supercharged 4.0L V-6, full suspension....
This is the car that is in the background (PICTURE 1) , owned by a friend of mine:
![](https://sphotos-b.xx.fbcdn.net/hphotos-ash4/405609_340594242648145_819383220_n.jpg)
#99
#100
Lights were starting to get that yellow/hazed look again. Spent some time cleaning them up. Wet sanded them, and then took a variable speed buffer and some PLAST-X to em....I think they turned out good.
BEFORE:
![](https://sphotos-a.xx.fbcdn.net/hphotos-prn1/77625_503338959684941_713889593_o.jpg)
AFTER:
![](https://sphotos-a.xx.fbcdn.net/hphotos-prn1/136023_503339056351598_1210966701_o.jpg)
BEFORE:
![](https://sphotos-f.ak.fbcdn.net/hphotos-ak-ash3/55273_503339383018232_2088262394_o.jpg)
AFTER:
BEFORE:
AFTER:
BEFORE:
AFTER:
![](https://sphotos-d.ak.fbcdn.net/hphotos-ak-prn1/56270_503339316351572_1706664318_o.jpg)
