motor cutting out at high rpm
Old Sep 28, 2012 | 05:00 PM
90 stanger gt's Avatar
Hey guys I'm having a problem with my motor cutting out when I'm getting on it hard anywhere from 3500 to 5500 I've replaced everything in the ignition system new msd box and wires new accel high performance header plugs can't seem to get it to stop any help would be great thanks
Old Sep 30, 2012 | 01:11 PM
Tirefryer's Avatar
Just a thought.... Fuel pump getting week or not keeping up....
Old Sep 30, 2012 | 02:09 PM
AlsCobra's Avatar
A Man Just Needs Some....
I've seen this happen too many times in fox bodys and it's usually a fuel filter. Try that first.
Old Sep 30, 2012 | 06:41 PM
bob's Avatar
bob
I'd imagine its pretty easy to check with the port on the pressure side fuel line and fuel pressure gauge. Screw the gauge on observe the fuel pressure at idle and while revving it, a dramatic drop in fuel pressure will indicate if there is a problem with the fuel system.
Old Oct 1, 2012 | 07:10 AM
skunk21's Avatar
Check teh easy stuff Like Al stated. the fuel filter ( if dirty will starve the car at higher rpms) is easy but you can also put a temporary remote fuel pressure gage on the car where you or a pass. can see it and see what readings you get at the higher rpms. another issue could be the sock on teh fuel pump is partly clogged or has issues and can cause high rpm fuel starving problems and a weak pump.
Old Oct 2, 2012 | 09:55 AM
Would the fuel pump getting weak cause carbon deposits on the spark plugs? I checked the plugs and they look like they have been burning good except they have carbon deposits around the bottom of plug that normally means a bad tune mine had the sct chip in the computer! I also have a fuel pressure gage on the fuel line i wool check that to
Old Oct 2, 2012 | 10:13 AM
skunk21's Avatar
Not really. how many plugs we talking? I would need a pic ( a good pic) of a few plugs to get an idea. you need to pull them all and mark which cylinder they are from to get a good idea. only a few, like one or two could be a sticky valve. carbon deposits ( fouling) of an entire set could be a host of things... running rich, wrong heat range, dirty injectors/malfunctioning, weak ignition voltage,etc. you can trouble shoot and how bad they are can also lead you in a direction.
Old Oct 2, 2012 | 11:18 AM
It was all the plugs i changed them i was using stock heat range plugs can send a pic of them when i get off work
Old Oct 2, 2012 | 11:54 AM
skunk21's Avatar
thats fine I'll take a look at them. I'm wondering if it is a rich condition, have you pulled codes at all yet ?
Old Oct 2, 2012 | 02:03 PM
Its not displaying any codes! All the plugs look like this one
Old Oct 2, 2012 | 02:06 PM
AlsCobra's Avatar
Fuel filter yet?
Old Oct 2, 2012 | 04:18 PM
I haven't checked the fuel filter yet
Old Oct 2, 2012 | 05:19 PM
I just checked the fuel pressure out was idling a Lil bit under 35 psi when you rev it up it jumps to 40 psi then settles at a Lil over 30 psi while running
Old Oct 3, 2012 | 04:43 AM
90mustangLX's Avatar
Did you let the car warm up a little then do a WOT a couple times while watching the gauge? Now easing into WOT but full on stabbing it WO?
Old Oct 3, 2012 | 06:39 AM
No i didn't let it warm up very long! I didn't hold it all the way open but i opened it up a Lil bit
Old Oct 3, 2012 | 06:44 AM
AlsCobra's Avatar
It requires more fuel when the car is under a load also. I'm still calling fuel filter. If not, I only costed you about $12.
Fuel pump upgrade never hurts either.
Old Oct 4, 2012 | 07:25 AM
skunk21's Avatar
I'm with Al, start with the fuel filter so you can rule it out. then if you are still having the issue you need to get a fuel press. reading under cruising loads. 35 psi is in the range with vacuum connected to reg. if the problem is still happening after the filter change we need to see what the FP is doing under a load, ie a weak pump, ir even a faulty reg. etc.
Old Oct 10, 2012 | 02:38 PM
It has a bbk adjustable fuel pressure regulator so out couldn't be that i will try the fuel filter if that don't help then i will upgrade the fuel pump it has a 190 lph now i guess i will go with the 255 lph
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Evil_Capri
Sep 25, 2015 12:56 PM
