Lowering springs
Old Mar 9, 2013 | 08:12 AM
notchos 90's Avatar
Lowering springs
Hello everyone, I have a 90 notch ssp I just installed a set of lowering springs, the front end is slammed but the rear looks like it never moved from the stock height any one run in to this issue? Thanks.
Old Mar 9, 2013 | 08:20 AM
skunk21's Avatar
which brand and spec of springs, did you keep the iso's or remove them? springs need time to settle but the look shouldn't be extreme.
Old Mar 9, 2013 | 09:09 AM
notchos 90's Avatar
I got the springs from C.L no brand on them the guy said he got them from mustang resto and that the drop on the springs are 1.5 at all 4 corners. Iso's are installed in the rear only.
[ATTACH]132312[/ATTACH
Old Mar 9, 2013 | 09:16 AM
notchos 90's Avatar
Old Mar 9, 2013 | 12:02 PM
11SHELBYGT500's Avatar
132312132313
You bought generic springs? Why?
Old Mar 10, 2013 | 07:42 PM
notchos 90's Avatar
Yeah I guess I did buy generic springs lol.I think I'm going to cut the rears and call it a day, no wa y I'm going to remove and install another set, the front one's were a pain in da a$$!
Old Mar 11, 2013 | 08:01 AM
skunk21's Avatar
Try removing the lower isolators in the rear 1st ( good for about 1/4inch or so) and then the uppers if needed..although I would run the tops imo. I have my lowers out with a small piece of 5/8s heater hose around the coil. No nvh problems at all. alot of arguements over this but it has been done for years w/o any major problems. if you feel the ride has changed then put them back in. It takes a few hundred miles for the springs to settle. I waited a long time for mine to settle and had just a slight rake in teh rear. removing the rear lower iso fixed it and now she sits perfect.
Old Mar 11, 2013 | 06:57 PM
notchos 90's Avatar
Ok I'll try that and I'll let u know if it did the trick. Thanks.
Old Mar 14, 2013 | 08:00 PM
notchos 90's Avatar
I'm thinking of going adjustable coilovers in the front and by raising the front and removing the top iso's in the rear it will level out. What y'all think?
Old Mar 15, 2013 | 10:45 AM
BA Mustang's Avatar
What color were the springs?
Old Mar 15, 2013 | 04:29 PM
notchos 90's Avatar
The color of the springs are red.
Old Mar 15, 2013 | 10:30 PM
BA Mustang's Avatar
Yeah those are the old SVE springs that Late Model Restoration sells. I have them on the 01 GT my family has and the rear didn't drop much at all, but the front did.
Old Mar 15, 2013 | 10:42 PM
notchos 90's Avatar
Yep those are the ones. I just order front coil over kit.
Old Mar 23, 2013 | 05:21 AM
NaomiDstangLvr's Avatar
How long have they been on? Doesn't it take some time for them to "settle"? Mine got a bit lower after a while..
Old Mar 23, 2013 | 08:16 AM
skunk21's Avatar
post #2 and #7
Old Mar 23, 2013 | 09:34 AM
Originally Posted by skunk21
post #2 and #7
Sorry, didn't notice that. Guess the woman should keep her nose out of the mechanical talk lol!
Old Mar 23, 2013 | 10:29 AM
skunk21's Avatar
No you should get involved just pointing out where the info was since I figured you over looked it.
Old Mar 23, 2013 | 01:07 PM
notchos 90's Avatar
Removed the springs in the front and installed gratinelli front adj coil over kit.
Old Mar 23, 2013 | 01:15 PM
notchos 90's Avatar
I'm ordering a set of granitelli rear lower adj control arms. You can adj (lower)the rear springs by as much as 1.5".with stock springs, in my case my lowering springs that didn't drop. LOL.
Autotooner
Nov 24, 2017 12:42 PM
GeoWett
Sep 30, 2015 06:40 AM
Evil_Capri
Sep 25, 2015 12:56 PM
