locked myself out, need help
Old Mar 19, 2015 | 11:48 AM
osso12's Avatar
Angry locked myself out, need help
on my 93 coupe like a ******* i left my key in the ignition and locked the door... All I have is an extra ignition key, no extra door key.... besides calling a locksmith what can I do to maybe jimmi the door?
Old Mar 19, 2015 | 03:01 PM
TripleBlack14's Avatar
Blonde on the phone: "Hello, locksmith...I locked my keys in the car and I need you to come right away
Voice: "Sure. I can be there in an hour".
Blonde: "Please hurry. It's starting to rain and I left the windows open".
Sorry to hijack your thread.
Old Mar 19, 2015 | 03:09 PM
osso12's Avatar
Bought a slim jim. Took me less than 15 seconds to get in the car.
Old Mar 19, 2015 | 03:48 PM
=HYPERDRIVE='s Avatar
Old Mar 19, 2015 | 04:15 PM
MadGT's Avatar
Legacy Tms Member
Ha, good one.
Old Mar 19, 2015 | 05:39 PM
glad you got in. You can also pry the top corner of the door out and put something in there to hold it out, rubber coated pliers work or a small piece of wood, then use something to hit the unlock button. A metal rod something thicker than a coat hanger or two coat hangers taped together and bent just right.
Old Mar 19, 2015 | 05:43 PM
houtex's Avatar
So, you can use what's called a slim ji...
...oh. Well, nevermind then.
Old Mar 19, 2015 | 07:21 PM
You guys are nuts. I don't see how anyone could possibly open a door with this.
Old Mar 20, 2015 | 06:10 AM
you have to smash them down flat and then they werk just fine
Old Mar 20, 2015 | 06:52 AM
Illi73's Avatar
Gt 5.0 Tms Member
I used to remove the antenna and stick it thru the top corner of the door to get in. Ford wasn't thinking too hard when they designed these cars.
Old Mar 21, 2015 | 06:50 PM
Jim74656's Avatar
Oh this just made my night...
Old Mar 22, 2015 | 12:05 PM
ford4v429's Avatar
legacy Tms Member
http://freetheflash.com/audio/blonde-star.php
I liked the family guy cartoon a few posts up too...
years ago(1996?) went out to warm up wifes car and brush the snow off... took the keyfob off and locked the doors. unlike my other cars, the fob wont unlock with engine on- had to call the locksmith, couldnt slimjim, as a 95 contour uses electric motors to lock/unlock(yeah a dead battery would be bad), but he had a slick tool, like a rod with a hoop on it- push the whole thing under window belting, pull back up, the hoop is inside, push back down and use the end of the hoop to press the lock switch...
Old Mar 25, 2015 | 03:16 PM
osso12's Avatar
Angry
my isssue is still not quite over.... NOW...the lock cylinder free spins.... if you lock the door now....you cant get back in as the cylinder turns and turns.....what the hell did I do? knock part of the linkage off? I dont wanna take the dam door apart to fix the freakin thing. anyone wanna buy a low 7 second coupe? frick!
Old Apr 6, 2015 | 10:32 PM
osso12's Avatar
Old Apr 7, 2015 | 08:54 PM
houtex's Avatar
I'll give ya $50 bucks now. I can have another $50 bucks next month.
Oh, you mean the lock, not the car... sorry.
Hey, I *said* I wuz sorry!
Anyway, yep. Likely the rod is not on it, so it is spinning around and around and around... gonna have to take the door apart and fix it.
It's NOT that bad. Just irritating, sure, but keep the window up, take the door panel off, and you'll see it right there, pop the thing back on and tada and stuff.
Only problem *MIGHT* be that you will need a new rod clip on it, 'cause it's plastic IIRC. Only way to know is to get in there and see.
While you're in there, throw some grease on the window regulator gears and sliders, 'cause might as well.
Fedupdave42169
Oct 20, 2015 10:29 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
