KYB AGX shocks and struts
Old Nov 7, 2005 | 07:37 PM
Valentino's Avatar
When I get the money (that means never) I'd like to get aftermarket shocks and struts. I wish I could afford tokico or bilstein but KYB seems to be the value quality brand. Before I make any purchase I'd like some insight as to how the AGX adjustable series holds up.
So if any of you guys are running or once did use the AGX or has a buddy that does, please tell me the pros and cons. I'm mostly concerned about street use cause I rarely see the track
Old Nov 7, 2005 | 09:02 PM
glowstang93's Avatar
I have the GR2 struts and shocks with no problem, my mechanic/friend sais they are built better than Monroe's
Old Nov 8, 2005 | 04:49 AM
mustangdaren's Avatar
running kyb gr2 also with no problems
Old Nov 8, 2005 | 03:30 PM
Daysleepin's Avatar
Can't say much about any specific brand.
But I have had the experiance of removing the front struts from one of these ponies.
It took a large flat tip screw driver and a box end wrench.
The screw driver holds the center stud while rotatang the nut counter clock wise.
At first the nut was stuck really super tight beyond belief.
So I heated the nut with a $9.00 propain from Walmart.
Once the nut was Glowing cherry red I put the wrench and screw driver to it and it turned so easy. Sorta, like cutting butter with a cherry red hot knife.
Trust me though, Keep using the wrench and don't try using your fingers. OUCH
Old Nov 8, 2005 | 03:34 PM
Valentino's Avatar
I already know how to take the the struts out, plus I have a spring compressor and and impact tools to make it much quicker and easier.
the GR-2 line is the stock replacement series so its not exactly what i'm looking for
ricky1728
Feb 11, 2016 07:25 PM
GeoWett
Sep 30, 2015 06:40 AM
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
robjh22
Sep 8, 2015 12:31 PM
