idle
Old Aug 30, 2011 | 10:38 AM
jonb's Avatar
idle
92 gt, Hey Im having issues with the timing or air control. It goes from 800 to 1600 then will sometimes cut off.when i crank it,it may run or just cut off. I have replaced the air mass flow, throtle sensor..I did adjust the timing a lttle and it does drive better. so is it the distributor. Ive been told it is..not sure.. I replaced the plugs and every since its been crazy .can anyone help...no mods as of yet, I have just got it.. WIRES are good, button good.any help p or ideas please???
Old Sep 3, 2011 | 10:10 PM
93slowstang's Avatar
Did you pull the spout connector to adjust your timing? You may need to check you tps sensor voltage to make sure it's correct, or reset your idle.
Old Sep 8, 2011 | 03:32 PM
x21's Avatar
x21
Maybe idle air control and/or vacuum leak, too.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
Airborne42
Sep 24, 2015 11:01 AM
samjluck
Sep 17, 2015 10:24 PM
