How to remove gas tank on a 86 GT?
Hello all,
What are the steps to remove a gas tank on a '86 GT vert? I have a leak somewhere, if I have more then an half a tank of gas, it leaks from the driver side somewhere, I need to take the tank out to see where?
Thank you,
Thank you,
Service Manager
If it leaks from the driver side then I'd bet it is leaking at the seam at the front corner of the tank where the exhaust passes by it. That is a common problem...especially if anyone ever moved that folded lip to clear an aftermarket exhaust system. You should be able to see the tank wet in that area without removing it.
Removal is simple though....unbolt the straps in front of the tank, unbolt the retaining ring on the fill side...lower the tank and disconnect all lines and slide it off the fill neck. It helps if you have almost no fuel in the tank....liquid is heavy and the tank will be too if it has any amount of fuel in it.
I restored my '68 mustang myself, but have not really worked too much on the fox bodies, but I will now!
Thanks again!
Service Manager
Thank you, the car is totally original so no aftermarket exhaust has ever been installed. When I unbolt the straps, there is a plastic shield on the tank correct? That should come off then I should be able to see that tank? Now a dumb question, did the '86 come with an electric fuel pump, if so is that on the tank?
Thanks again!
Thanks again!
The '86 does have an electric fuel pump but it is inside the tank, not on it.
If the tank is leaking I would not recommend trying to patch it....a new tank is around $100 so it is best to replace it.
Be careful to not tear the filler neck seal....otherwise it must be replace or you will have a fuel leak on the passenger side of the car....
Yes, there is a plastic shield. I usually leave it on until I remove the tank because I have something supporting the tank under that shield. Then once out lift the tank up out of it. Nothing holds the shield to the tank other than those straps.
