How do I change my fuel injectors?
Hey guys,
Looks like the upper intake has to be removed in order to change out injectors?
As always, thanks in advance...............Mike
Upper Plenum comes off, throttle body all stays connected to the plenum, 4 bolts hold on the fuel rail then un-plug the connectors, some will crack and twist them out. Be careful not to drop anything in the intake, cover as soon as the plenum is off. Pretty basic, just watch out for those loose items. Depending on how long they have been there they might stick and the O ring will stay but its easy to get them out with an L pick or tiny screwdriver..
You got that right!!!
LOL not on this end man, you must have some huge *** fonts.
![Banana](https://themustangsource.com/forums/images/smilies/banana.gif)
Figures I have to take the upper off, those **** screws that hold the plate on are stripped.
DerekShiekhi
9/30/15 06:59 AM
