horn wont work
Old May 27, 2012 | 09:29 AM
88 stallion's Avatar
horn wont work
I have an 88 gt and the horn won't work. I thought it might be the fuse but everytime I put a fuse in , it blows the fuse every time. Idk
Old May 27, 2012 | 10:49 AM
BoogieNights's Avatar
BoogieNights Studios:
Official Fluffer
You have a short somewhere in the horn system if you are blowing fuses.
Old May 30, 2012 | 09:47 PM
So where would I start looking to find a short? Any place particularly ?
Old May 31, 2012 | 05:14 AM
skunk21's Avatar
here is the horn wiring
work from the fuse out or the horns in then from the steeringwheel control back to the fuse if needed. ( you can ignore the light wiring hron is on teh bottom)
Old May 31, 2012 | 05:23 AM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
whats that old bumper sticker say? "horns broken, watch for finger"
Old May 31, 2012 | 05:29 AM
skunk21's Avatar
Old May 31, 2012 | 05:58 AM
Yea, if inspection didnt require horn to work I would definitely use that method
Old May 31, 2012 | 06:03 AM
AlsCobra's Avatar
A Man Just Needs Some....
Find the horn relay first. Pull the relay and put a good fuse in it. If it doesn't blow the fuse, it's going to be between the relay and the horns. Also swap relays with one just like it if you can. If the relay is stuck it will blow the fuse as soon as you put a new fuse in it. But it still may be a shorted horn also. Do this and report back.
Old Jun 7, 2012 | 10:27 AM
Replaced horns and horn button. Works fine now
Antigini-GT/CS
Oct 5, 2015 09:43 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
DrVet
Sep 23, 2015 01:48 PM
BigHoss
Sep 21, 2015 10:03 AM
tbear853
Sep 8, 2015 11:18 PM
