Fuel pump
Old Sep 5, 2011 | 09:39 PM
nochevyshere's Avatar
Fuel pump
I gotta 87 gt and I was wondering if any one else has had problems with yours. I put my gas line to a gauge and it say I only have 20 fuel pressure and from what have read I believe it's suppose to be 45 psi. When I purchase a new one I think I am gonna get a msd high pressure one but idk let me know what you think.
Old Sep 5, 2011 | 09:44 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Well. I personally don't think your car needs it unless your boosted. Also check to make sure your filter is just not clogged.
Old Sep 5, 2011 | 09:56 PM
Yeah that was my first thought put a new one on still all boggy and you can tell not enough fuel so then I was lookin and there was a kink inthe line so I replaced that then the guy before me whenhe put the msd distributed on and I look and wire 3 and 4 were crossed replaced plugs after fixing all this it's runs just a little bit better that's when I checked the pressure on the pump an it's low when it idles it's fine bu when you step into it it bogs idk
Old Sep 5, 2011 | 10:01 PM
Bear Eats King...
Bear ****s Bone
Refresh my memory? Electric or mechanical fuel pump?
Old Sep 5, 2011 | 10:03 PM
Mine is electric
Old Sep 5, 2011 | 10:07 PM
Bear Eats King...
Bear ****s Bone
Pull your fuel regulator vacuum hose off while it is running. Is it leaking gas? Did the idle improve? Sounds like a regulator with a bad diaphragm
Old Sep 6, 2011 | 07:57 AM
Ok I will try that and get back to ya idk way else to do haha thanks
Old Sep 6, 2011 | 08:05 AM
Bear Eats King...
Bear ****s Bone
Ok. Good luck
Old Sep 6, 2011 | 08:18 PM
91gt's Avatar
I had the same problem with my 91 I replaced the fuel pump and it fixed it
Old Sep 6, 2011 | 10:03 PM
I haven't gotten to it yet but I will let yal know
Old Sep 9, 2011 | 07:08 PM
I replaced the fuel pump and let's just say my dads 06 couldn't keep up with me haha that's a good thing
Old Sep 9, 2011 | 07:40 PM
Bear Eats King...
Bear ****s Bone
Alright nice!
Old Sep 9, 2011 | 10:37 PM
I'm satisfied ha
NC14GT
Feb 20, 2023 09:42 AM
Sep 16, 2015 06:44 PM
Beouch
Sep 16, 2015 06:14 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
