Engine Swap..whats it take?
Have a 1980 hatchback, with a 200 six, want that thing out of there and a 302 (yes it's still a 302 to me I'm old) in it's place. Anybody have any idea what it will take to effect the swap? Parts that is... I have no idea what chassie parts will swap between the two engines, if any. The car currently has a C4 transmission in it. I know some of you guys can help me out. Oh I usually hang around the 05 V6 board, very new to this board...Thanks for any and all help....
Service Manager
Well to start you must change the K member....a 4 cyl and V8 are the same but the inline 6 cyl has a K member all it's own with different mounts.
Aside from that the parts are pretty basic and if you plan to run a carb then that too is a simple setup.
hi i may be able to help you here i have a 94 engine box k member front brake asembly springs shocks cia msd dzzy coil and control module underdrive pulley and a 250 amp alternator for sale you can have the prop and back end if you want as well also the ecu and harness are available to stripping mine out for a project however i must warn you the engine needs a new head gasket also bbk equal length shorty headers and a custom exhaust with h pipe make me an offer
Evil_Capri
9/11/15 08:39 AM
