Door Lock Actuators.
Old Dec 29, 2007 | 06:25 PM
Stix66's Avatar
Does anyone know if there was/is a recall for the door lock actuators for a '93 GT?
I am just asking because everyone says this is a common problem in Foxes, and I was just wondering if Ford took any action.
Old Dec 30, 2007 | 08:09 AM
GT5088's Avatar
not as far as I know... personally, I have owned three foxes and have had the same problem with all three...I guess its just something you have to deal with. Ford's are notorious for electrical problems...
Old Dec 30, 2007 | 12:40 PM
svopaul's Avatar
Service Manager
NO, no recall there....
and it's not an 'electrical problem" either.....the problem is that the rubber boot that is designed to keep moisture out of the actuator deteriorates and allows moisture to run down the shaft into the actuator which is what causes the failure....corrosion...not electrical.
Old Dec 30, 2007 | 03:05 PM
Stix66's Avatar
Thanks for the info guys! I have to replace these now because now that it is cold I can not even get into my car with the key, and I can't even get out sometimes... I have to use the hatch its ridiculous lol.
Have a Happy New Year!
Old Dec 30, 2007 | 05:36 PM
x21's Avatar
x21
just be lucky you dont own a hardtop then
By the way, how come you cant just pull on the inner handle to get out? is that broken too?
Old Dec 30, 2007 | 10:13 PM
Stix66's Avatar
I don't think its broken but the lock actuators are so messed up that I can not move the lock pin on the door up unless I use a key. Some days I can open my doors from the inside, if it is not below freezing usually.
Old Dec 31, 2007 | 06:21 AM
svopaul's Avatar
Service Manager
That is familiar and when it is below freezing the moisture on the actuator rod that has seeped into the actuator gets frozen and there is NO WAY you will get into the car until it thaws out.(unless you have a hatch).
Old Dec 31, 2007 | 07:30 AM
Ren 89's Avatar
I have the same problem with the driver door. It still works, very stiff. Power lock will not work at all. It's on my "to do" list.
Old Jan 1, 2008 | 12:47 AM
Stix66's Avatar
Yep thats exactly what I have had to been doing some mornings to go to work... lol
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
