Coil spark
Old Jan 17, 2013 | 08:56 PM
prado86's Avatar
Coil spark
How do i check if my coil is sending spark to my distributor?
How do i check if my distributor is sending spark to the spark plugs?
Or how do i know if either one took a **** on me?
Old Jan 17, 2013 | 10:10 PM
SleepingStang's Avatar
Pull a plug out and disconnect the coil wire. Plug the spark plug into the coil wire, hold the plug to a spot on the block. Have someone crank the car over in short bursts and watch for spark. Do not arc yourself while checking, you may want to hold the boot and not the plug itself. If you have good solid spark the coil should be fine. If that's good you will have to replace the coil plug on the distributor cap and then check each plug in a similar fashion. If you are getting no spark anywhere it could be the module on the bottom of the distributor. Hope this helps and use at your own risk. If you have a Haynes or Chilton's manual they have a service and check procedure.
Old Jan 18, 2013 | 09:01 AM
prado86's Avatar
Mpaps
Oct 11, 2017 08:06 PM
GeoWett
Sep 30, 2015 06:40 AM
earl610
Sep 6, 2015 05:48 PM
GTown3r
1994-2004 V-8
Aug 30, 2015 08:04 AM
