Car jerking aftet the eninge heats up
Old Apr 26, 2011 | 05:17 PM
darkhorse93's Avatar
I have a 93 Foxbody that is supercharged and after driving for a while the car starts to jerk when you get on the gas, but at idle it's fine? Anyone know what can be causing this? Thanks
Old Apr 26, 2011 | 05:35 PM
HOSS429's Avatar
legacy Tms Member
plug wires breaking down ?.. look at your engine running in the dark and see if there is any arching from the wires ..
Old Apr 26, 2011 | 06:45 PM
It's only does it sometimes, usually after driving the car after a while. But I'll check thanks
Old Apr 26, 2011 | 07:55 PM
It will hesitate when you get on the gas and then jerk really bad but the it will work itself out
Old Apr 27, 2011 | 07:54 AM
Evil_Capri's Avatar
Moving to 'Fox Mustang' section, but will leave a link for today . . . .
Old Apr 27, 2011 | 08:38 AM
afr347strokerman's Avatar
What size injectors and fuel pump do you have? Is the car tuned?
Old Apr 27, 2011 | 12:55 PM
I'm running 42lb injectors and a 255 walbro pump. And it is tuned
Old Apr 28, 2011 | 12:42 PM
That pump might be on the small side...not saying its the answer but process of elimination...
Old Apr 28, 2011 | 02:03 PM
What would you suggest going with then?
Old Apr 28, 2011 | 03:39 PM
Maybe a hi pressure pump for superchargers...check out aeromotive...pricey but worth it. Pull your plugs and re me what color they are ... black...grey...etc
Old Apr 28, 2011 | 05:57 PM
They are black. Is possible that since I got my tune done I did some other work to the engine and that's throwing it off
Old Apr 28, 2011 | 10:47 PM
Too rich...check your fuel pressure. Who makes your injectors? Mass air might be trippn...how's the idle?
Old Apr 29, 2011 | 04:25 AM
They are ford racing injectors. The idle is fine till it starts acting up.
Old May 15, 2011 | 07:41 AM
So I figured out what it was. It was a combination of the spark plug wires and the fuel filter. I'm pretty sure it might have been the original.
Old May 16, 2011 | 06:24 PM
HOSS429's Avatar
legacy Tms Member
you`re welcome
Old May 16, 2011 | 08:14 PM
And then today I opened up the distributer cap and there's a ton of carbon and all the teeth are worn. Maybe that's it
Ecostang
Nov 3, 2022 08:50 PM
jc46002003
Apr 15, 2016 03:00 PM
apial
Sep 6, 2015 10:40 AM
f1-cobra
Aug 1, 2015 08:02 PM
GT227
'10-14 Interior and Audio
Jul 13, 2015 11:42 AM
