Bought a FOX, Only got 4th gear...HELP
Old Nov 23, 2008 | 09:06 AM
FLAstangx3's Avatar
Question Bought a FOX, Only got 4th gear...HELP
Soooooooo, bought my son his first Mustang. 86 Fox 5.0, 5 speed. Last night while driving he heared a clunk, now only has 4th gear.
Any suggestions as to where to start??????? Really don't his friends to start taking it apart looking aimlessly. Had many a comment, from Throw-out bearing, Clutch, shifter, rear end, U-joints.
Where would you start to look ??????
thanks.
Old Nov 23, 2008 | 08:47 PM
lp9820's Avatar
will the shifter go into any of the other gears, does it seem like its in neutral when in those other gears? describe what happens when you move the shifter into the other gears? and describe the "clunk" sound, tell me more and i may be able to help, need to put my fancy book learning to some use
Old Nov 24, 2008 | 06:25 AM
not the rear end or ujoints. Does the clutch still work, when you push the clutch in while the car is running will it disengage or will the car try to keep moving
Old Nov 24, 2008 | 09:30 AM
lp9820's Avatar
it may be either the input gear or the first cluster gear may be stripped, you'll still have your 1:1 gear(4th) but you wont have the other gears since the cluster grears arent rotating so no rotation is being transfered to the other gears.
Old Nov 30, 2008 | 12:23 AM
edumspeed's Avatar
Legacy TMS Member Pr
If the clutch operates, then you've got a blown tranny. That's teh suck.
Old Nov 30, 2008 | 12:11 PM
FLAstangx3's Avatar
Just took it out. It's the Cluster gear.
Now problem #2. The Sway bar is rusted off on one side. Anyone know where I can find a "Blow-up" Diagram of this sucker, so I can take it out the proper way. ie;s, how does it bolt up. And then, of course, the replacement, any upgrades out there, before I put a stock one on it.
Old Nov 30, 2008 | 05:23 PM
lp9820's Avatar
give me a day or so and i may be able to get you the steps from alldata
Old Dec 15, 2008 | 06:29 PM
photolabgirl77's Avatar
Try latemodelrestoration.com for fox parts. Thats where I got my new fan clutch.
trackpack13gt
Jul 25, 2017 05:29 PM
blackhawkkid308
Sep 30, 2015 04:04 PM
RoushRS3
Sep 29, 2015 08:03 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
