Belt Help
Old Jan 20, 2006 | 04:41 PM
Autotooner's Avatar
My C/T is cooler than Arin is.
I am removing the A/C from my car... the motor is a 200 i6... I want to know what kind of belt would I need to get for my car? Thanks
Old Jan 21, 2006 | 09:24 AM
joker's Avatar
I have no clue what belt it would use. Why not just use a peice of string to measure it? Take a long piece of string, and run it just as you would the belt, and cut it once you get back to your starting point. Then check and see if you need to add a little length, or subtract a little length considering that the tenios pulley need to pull the belt tight. That should get you in the ballpark of your needed belt length.
jc46002003
Apr 15, 2016 03:00 PM
bigaaron
1994-2004 V-8
Aug 22, 2015 12:06 PM
ghostrider024
1994-2004 V-6
Aug 10, 2015 02:32 PM
berzerk_1980
Jul 23, 2015 12:35 AM
