5 lug conversion
Old Dec 29, 2005 | 05:13 PM
88GT_03V6's Avatar
I have an 88 GT and would like to buy rims, im just wondering how hard it is to convert 4 lug to 5 lug? BTW these are the rims that I want, how do u think that they will look on a black 88 GT
http://us.st11.yimg.com/store1.yimg.com/I/...et_1873_3817829
Old Dec 29, 2005 | 05:30 PM
svopaul's Avatar
Service Manager
In order to get those wheels to work you will have to change over the front suspension to the 94-04 style brakes...spindle assy and you will have to change your tie rod ends to the newer style as well.
The old way was a simple rotor change on the front but those wheels will not fit the old rotor style.
For the rear you can either get the FRPP 5 lug drum kit or change over to disc brakes.
Old Dec 29, 2005 | 05:44 PM
88GT_03V6's Avatar
Thanks, but sounds like a little to much work for me, maybe i'll find 4 lug rims that i like
Old Dec 30, 2005 | 06:29 AM
conv_stang's Avatar
have never seen 4 lug rims like that only 5 lug. and if you are mechanically inclined it wont be too much of a problem. the hardest part will be changing the rear axles
Old Dec 30, 2005 | 08:37 AM
PACETTR's Avatar
Actually you can use existing tie rod ends with machined spacers. Some have used washers instead. Otherwise right on...
Old Dec 31, 2005 | 11:44 AM
kevinspann's Avatar
ARB axles and drums can be used instead on ordering the Ford Racing kit, right? I do have a question however : Why can't rear disc brakes from a lincoln be bolted to the 8.8 rearend in a Mustang?
Old Jan 11, 2006 | 03:16 PM
flamesarewicked's Avatar
u can just buy a 5 lug conversion kit from summitracing for like 400 bucks...basicly its just the front rotors with 5 lug pattern and the replacement axles and drums...
Old Jan 21, 2006 | 12:50 PM
kevinspann's Avatar
I just saw the Brackets that let you use Cobra/Bullitt brakes on a fox-rear - cool
DEPUTY62
Sep 12, 2015 11:12 AM
oldnjguy
Sep 10, 2015 02:39 PM
