Notices
Anybody everhave this issue with installing/removing heads still on the car?
Old 4/20/13, 12:49 PM
82 GT's Avatar
When I was removing my heads, to take to the machine shop, I had a rough time getting a good angle with the wrench to remove some of the bolts. Then I realized that it's going to be just a hard to install them again.
Anybody ever have this issue before and what did you do to make it easier? I had trouble with the bolts towards the firewall.
Old 4/20/13, 02:19 PM
onebadvert's Avatar
I dont have any trouble with my head bolts. You may have to loosen up the header collector to move it a bit if your talking about the lower bolts.
Old 4/20/13, 07:18 PM
82 GT's Avatar
I took the headers completely off. I did manage to get them off but needed to use a swivel extension on a few of them and even that was tricky.
I just want to be able to get a solid angle on them when I install them to get them fully torqued properly.
Old 4/22/13, 04:06 PM
90mustangLX's Avatar
When I swapped the heads on my 90 I had no problem getting a long socket in every bolt. Needed an extention for the lower ones but otherwise no problem.
Old 4/22/13, 04:10 PM
skunk21's Avatar
plenty of room when I did mine also.
Old 4/23/13, 02:05 PM
82 GT's Avatar
Remember, you guys all probably have a 5.0, where I have a 351w in my foxbody. I think the taller deck height is what's giving me trouble.
Old 4/23/13, 03:41 PM
MustangFrontier's Avatar
Probably. Use a swivel adapter and extensions, preferably with an impact. Another option is undue motor and trans mounts and move engine forward ( lotta extra work tho)
Ecostang
11/3/22 08:50 PM
ssjbuu
8/28/15 08:55 AM
SpectreH
8/3/15 03:30 PM
Bullitt 3309
8/2/15 10:20 PM
tony2014mustang
7/19/15 11:39 AM
Quick Reply: Anybody everhave this issue with installing/removing heads still on the car?
