AC low fitting to refill system?
Old Jun 19, 2013 | 06:17 PM
Tyson30's Avatar
Which fitting is the low side fitting so I can refill the system, i think its the red one but i just want to be sure.. its all new stuff so there's no r-12 in the system, I just have to convert the fittings to
r-134a fittings.
Old Jun 19, 2013 | 07:54 PM
houtex's Avatar
See that 'S' on the one in red? That means 'Suction'. Suction means low pressure. There ya go. You'll notice the other one, the blue one, leads to the fitting on the compressor that has a 'D' for Discharge.
Also, I want to say proper fittings for both R-12 and R-134, and adapters thereto, are not reversable. That is, the high side can't be connected to low side hoses, and vise versa. If you have a set of gauges, the blue hose goes on the red circled port, and the red hose goes on the blue circled port, and should NOT go on the other way, even with the adaptors.
Anyway, 'S', the red circled one, is the one you want.
Old Jun 20, 2013 | 07:44 AM
Tyson30's Avatar
Thank you very much for your help, much appreciated..
Old Jun 20, 2013 | 08:32 PM
houtex's Avatar
You're most welcome and good luck!
Old Jun 25, 2013 | 08:01 AM
Tyson30's Avatar
Thank you for you help, charged the system and its ice cold, thanks a lot.. Only thing I notice now is the water temp runs hotter now, is that normal?
Old Jun 25, 2013 | 07:56 PM
houtex's Avatar
If the water temp is higher it's because the added heat of the A/C condenser is not allowing the radiator to work as good. The condenser sits in front of the radiator, and the air goes in to that, carrying the heat from that into the radiator and then out the radiator.
It indicates a potential radiator problem, unless the car was running far cooler than it should be... but that's what the thermostat is supposed to prevent. Might want to have the cooling system checked out, just in case.
Old Jun 26, 2013 | 09:50 AM
tom281's Avatar
Whoa houtex with tech advice?
//never woulda guessed
///mind = blown!
In all seriousness though two thumbs up!
Old Jun 26, 2013 | 07:21 PM
houtex's Avatar
Heh, I'm not just another pretty face with wit and charm and irritating ripostes. Thanks much for the complement, Tom. I love to help when I can. After all, we're all in this thing together, tryin' to keep cars running, right?
/Air conditioning a '66 Thunderbird will learn you a thing or two, lemme tell ya.
//Way way not enough air movement outta them center vents, but hey, they had *joysticks!*:
Old Jun 27, 2013 | 10:44 AM
Tyson30's Avatar
I think i figured it out, I sprayed the hell out of the the radiator and condensor with my hose and all sorts of crap was coming out, since then its been running great. Thanks for your help again
Old Jun 27, 2013 | 10:46 AM
That's good news
Old Jun 27, 2013 | 08:10 PM
houtex's Avatar
Awesome to hear!
FromZto5
75
Oct 5, 2015 02:27 PM
DrisStang
Sep 14, 2015 06:20 PM
Sep 8, 2015 10:45 AM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
