'92 GT Fog Lamps Problem
Old Feb 6, 2011 | 07:11 PM
Leroy's Avatar
I recently overcame the flashing headlight problem by installing a new switch. I've discovered the real problem to the headlight flashing (under-sized wiring) and will fix it soon. But this isn't that problem. My fog lamps have quit working. They worked after I replaced the headlight switch, but have stopped now. I put the old switch back in and still nothing. Oh, and yes, I checked the fuse. Anything else I'm missing?
Thanks,
Lee
Old Feb 6, 2011 | 08:47 PM
jacostang's Avatar
Check the plug that goes into the switch.. They get burned because of the power that goes through after time.. The fix is to add a relay and then you can run your fogs independently from you head lights and also have them on with your hi beams.. Here is the fix..
http://www.corral.net/tech/maintenance/foglights.html
Old Feb 7, 2011 | 02:26 PM
Leroy's Avatar
I guess I might as well fix it right the first time and not have to do it again later. I've always wanted to have seperate control of the fog lights anyway. Thanks!
Old Feb 9, 2011 | 11:07 AM
Imatk's Avatar
Yep it's a good fix.
I actually had my relay go out after about 10 years
Went to radio shack and bought another one for 2 dollars or so and it works perfectly again!
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
