92 Fog Light Problem
Old Oct 21, 2005 | 07:47 AM
Twilightblu92's Avatar
OK, guys. I have a 92 GT and everytime I put in a new fuse for the Fog Lights it blows out. As you know this fuse also causes the airbag to function.
I've checked the wiring running from the lights to the wiring harness and everthing looks entact. What could be the problem?
Old Oct 21, 2005 | 06:12 PM
Anyone?
Old Oct 22, 2005 | 07:27 AM
Ren 89's Avatar
Electrical problems suck :bang: Just out of curiosity, is the fuse blowin after you switch them on, or is the fuse blowin immediately after you replace it. (Switch off) You mentioned the fuse also controls the air bag, (did not know) there could be a a problem with the bag and not with the lights that's causing the fuse to blow. I always cringe at electrial problems, they can be such a pain to figure out sometimes. Good Luck and let us know if ya figure it out.....
Old Oct 22, 2005 | 08:00 AM
It blows the fuse when I turn them on
Old Oct 22, 2005 | 08:04 AM
Ren 89's Avatar
How about the switch itself??
Old Oct 22, 2005 | 10:22 AM
Daysleepin's Avatar
Sounds like you need one of these.
With time and patience you can track down the short.
Thats if you into the perfect concourse show vehicle.
Altho most people including myself would find it easier to just run new wires to the fog lights.
Old Oct 24, 2005 | 04:11 PM
Originally posted by Ren 89+October 22, 2005, 10:07 AM--><div class='quotetop'>QUOTE(Ren 89 @ October 22, 2005, 10:07 AM)</div><div class='quotemain'>How about the switch itself??
[/b]
I don't know, but it's worth a shot. It's not too big a deal since I don't drive it in the winter and it's getting close to that time. I'll check 50resto and see what they have.
<!--QuoteBegin-Daysleepin
@October 22, 2005, 12:25 PM
[/quote]
Yea, I have a couple of those. I just haven't used it cause the wiring to the fogs still have the plastic cover on them and don't look worn, but I'll to that test also.
Thanks.
Old Oct 24, 2005 | 04:51 PM
Ren 89's Avatar
Just got my 50 Resto book the other day, looks like about $60.00 for the switch. (Page 13)(Vol 6) Good Luck...
Old Oct 24, 2005 | 06:03 PM
Thanks. I have a couple of those....keep one in the stang and one in the house. It's like an American Express for Mustangs
Old Oct 25, 2005 | 10:17 AM
BigBoyBoelts's Avatar
take out both fog lights, then replace the fuse, try the switch if they still blow its the wiring, if not then put one light in at a time, if it blows then its the lights shorting out.
If that's not it, then it might be the light/wiper arm shorted out.
Old Oct 26, 2005 | 02:17 PM
Daysleepin's Avatar
If your talking about the Head light/Fog light combo switch that at the left of the speedometer than try Auto Zone.
It was 27 bucks. but, that was a few years back. Surely its not up to 60 bucks tho?
Old Oct 27, 2005 | 08:05 PM
Coupe's Avatar
I agree with BBB. His suggestion is the simplest method .
The switch itself should be available at your local auto parts store for a few $$ less than on-line.
Old Oct 28, 2005 | 07:00 AM
Redbaron93's Avatar
I had the same problem when I had my '87 GT and it was the switch. They were known for failure.
Old Nov 1, 2005 | 10:43 PM
Thanks everybody for the help/info. I'm gonna play with the options tomorrow and see what happens.
Mpaps
Oct 11, 2017 08:06 PM
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
DEPUTY62
Sep 12, 2015 11:12 AM
Mrmiles1369
Sep 11, 2015 07:23 PM
14Glassback
Sep 11, 2015 04:50 PM
