89 GT Heads??
Old Jul 19, 2014 | 09:07 PM
foxguy48's Avatar
Hey guys after my return from this barren waste land that I am in right now I am planning on getting a new set of heads and want to know what you guys think I should get. I have been looking at the new trick flow 11R 190. Currently on the car CAI, BBK long tubes, X pipe, systemax II upper and lower intake, it has a cam in in no idea I think it's an alphabet cam, 19 lb injectors, c&l maf, and a pp throttle body not sure what size can't find the part number without taking it off. Msd 6al 2. As far as I know the car has stock internals bought it used off another soldier.Think that's about it I'm sure I'm forgetting something. The car is a 5 speed. I'm sure you guys get this a lot but thanks. Dan.
Old Jul 20, 2014 | 03:10 AM
AlsCobra's Avatar
A Man Just Needs Some....
I don't know the specs of that particular head but Trick Flow is a great choice. 2.02 valves and over 60cc chambers are the way to go. Trick Flow or AFR are both top choices.
Old Jul 20, 2014 | 06:07 PM
foxguy48's Avatar
How we'll does the Holley systemax II flow will it work good with the new trickflow heads and do u think I will have any piston to valve clearance issues?
Old Jul 20, 2014 | 06:16 PM
AlsCobra's Avatar
The Holley or any other aftermarket intake should work fine. Really haven't seen any 1 intake that much better than the rest. I like the GT40 intakes but mainly just because of the looks. Just pick the one you like looking at the most. Clearance should be no issue at all. A lot of people think that a smaller combustion chamber is good and it seems to make good sense but the 302 doesn't need it. In fact it does better with a 60-64cc head. The bigger valves is what you want. Those motors just need to breathe. All this 302 talk makes me want another Fox body.
Old Jul 20, 2014 | 09:03 PM
foxguy48's Avatar
I'm thinking the 66cc chambers that should be good with a stock bottom end.
NC14GT
Sep 10, 2017 04:47 PM
Sep 30, 2015 07:02 PM
FromZto5
Sep 30, 2015 05:28 AM
earl610
Sep 7, 2015 11:57 AM
