351w in fox
Old Mar 8, 2005 | 10:03 PM
gtmusselman89's Avatar
About to put a 408 in my fox and need to know about roller lifter and flywheel. Was told I can use my stock flywheel from my 302 as long as i balance the bottom end with it. Is this true? I thought 302 were 50oz and 351w were 28oz. And roller lifter. Can I take roller lifters from a 302 and the spider and install into the 351w? Was told they make a retrofit kit because the oil boss are different. :bang: Going crazy HELP
Old Mar 9, 2005 | 09:16 AM
svopaul's Avatar
Service Manager
OK...first the balance....I would recommend getting a correctly weighted flywheel....you could remove weight to get it down to 28oz if you have too but you are better off starting with the right flywheel.
Secondly the lifters....I've gone through this personally....you cannot use the stock roller lifters and spider because the lifter bosses are shorter...in you use the stock hardware you will have to run a small base circle cam in order for it to work...your best bet is to use the link-bar retrofit lifters that Crane sells....not cheap but neither is the other option so you are stuck either way. Each way will run in the $400 range. At least if you use the retrofit lifters you can run a standard cam and not have to go the custom small base circle route.
Old Mar 9, 2005 | 01:22 PM
Fordracing200's Avatar
and if you dont already have one, you will need a cowl hood OR a custom K member for the 351 to fit.
Autotooner
Nov 24, 2017 12:42 PM
JTB
Motorsports
Oct 29, 2015 09:07 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
JTB
Motorsports
Sep 7, 2015 10:20 PM
