1997 Explorer swap into 1989 5.0
Old Feb 11, 2012 | 09:42 PM
Kbolden50's Avatar
Im going to a shop and pick up a 97 explorer 5.0 engine with gt-40p heads and i looked up the swap and what i got out of it is change all front parts and timing cover balancer i want to know if thats all and can i use 5.0 mustang flywheel and the balancer off a 5.0 mustang and it work and can i use a 1989 Lincoln mark vii 5.0 HO cam in the 97 engine and the same roller rockers and rods out of the 89 or it there roller rockers in the 97 thank you
Old Feb 12, 2012 | 06:08 AM
dcpirani's Avatar
The 97 Explorer engine and the Linclon has stamped rocker arms (unless they have been changed). The cam from the Mark VII should work.
Old Feb 12, 2012 | 11:46 AM
Kbolden50's Avatar
Ok do you know if the 97 has roller rockers
Old Feb 12, 2012 | 02:53 PM
dcpirani's Avatar
No it does not. It has stamped steel rockers. I recently purchased a 1998 Explorer engine and tore it apart. I am just using the short block. Using accessory drive from my 5.0. Are you doing a V8 conversion or just swapping out the engine?
Old Feb 12, 2012 | 08:02 PM
Kbolden50's Avatar
I had did the swap from a 2.3 to v8 already but the motor went out so now I'm just changing the motor does the 97 motor have rockers
Old Feb 12, 2012 | 08:26 PM
hi5.0's Avatar
Like stated previously, the '97 engine should have stamped steel rocker arms, not roller (bearings) rocker arms unless the Explorer engine was previously modified. Swap what performance parts you can from your old engine onto the newer one. May need to look into a set of shorty headers that will work with GT-40P heads in a Mustang application.
Old Feb 13, 2012 | 06:00 AM
skunk21's Avatar
Like stated and now stated again the heads do not have roller rockers. The '89 mark cam can be used it is the same cam has the mustang. A nice upgrade that really makes a motor is a trick flow stage 1 cam IMHO. I would also get the ceramic coated Ford racing "P" headers, best bang for the buck shorty header and it is a well made header.
Old Feb 13, 2012 | 06:16 AM
dcpirani's Avatar
Swap everything from your current 5.0 to the long block of the Explorer and put it in. Like skunk21 said, get a set of headers that are made for the GT40P heads and enjoy!
Road_Runner
Sep 2, 2024 04:46 PM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Ray11
Sep 25, 2015 12:43 PM
Mustang65bob
Sep 21, 2015 11:30 AM
