1986 spring rates
Old Dec 13, 2012 | 07:20 PM
MRMOLE's Avatar
1986 spring rates
looking for the stock spring rates for my 1986 gt hatch back. i was going to get some ford racing springs and dont know what rate to get as it looks like there are two. its a a everyday driver and i dont whant to stiff but i do whant more then what i have now. and sugestions .
Old Dec 14, 2012 | 04:46 AM
skunk21's Avatar
late 84 thru 93 used a variable rate spring. The spring rates changed for 87 but for your '86 the front spring rates are 425-525, the rears stayed the same at 200-300. The B spring is a variable rate spring that will give a nice drop and offer about the same ride.
Old Dec 14, 2012 | 02:40 PM
MRMOLE's Avatar
thanks , i was thinking of going that way with poly bushings and better ball joints and shocks . i did see thay offer a stiffer spring (in a650lb ithink) but i dont know how stiff that would be . i dont what to rattel my teeth out.
Old Dec 14, 2012 | 02:55 PM
skunk21's Avatar
The progressive "B" springs are going to be a little stiffer than stock but give a better ride than "C" springs. "C" springs use the same progressive rear springs but a linear (constant) rate front spring which will be much harsher than the "B".
There is always going to be some trade off with spring changes over stock. a good set off dampers ( shocks/struts) control arms ( later when cash allows) and sub frame connectors are ways to improve the handling of the fox and it doesn't always have to be a kill your back ride either.
Old Dec 14, 2012 | 06:41 PM
MRMOLE's Avatar
thanks stunk21 thats a big help.
Old Dec 14, 2012 | 07:36 PM
skunk21's Avatar
Autotooner
Nov 24, 2017 12:42 PM
Fords4Ever
Oct 30, 2015 09:07 PM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
