will X pipe help on a 66?
Old Dec 4, 2007 | 09:26 PM
Dougxox's Avatar
Looking at beefing up my 200ci in line 6 with dual exhaust, will an X pipe help or do anything or am I better to just run two seperate exhausts in the traditional manner?
Old Dec 5, 2007 | 06:41 PM
codeman94's Avatar
what are you going to cross?.....its inline with one manifold....it should all come out of the same place, right?...lol...I think your best bet would be to get one of these...
http://www.mustangsunlimited.com/ite...atkey=EMUSTANG
Old Dec 5, 2007 | 09:26 PM
hiznherponies's Avatar
Yep, what Cody said!!
Old Dec 5, 2007 | 10:01 PM
Dougxox's Avatar
Was thinking about something like this:
Product ID: PMK-200-DOH
Dual Outlet Header
Details
Classic Inlines Dual Outlet Headers come standard with a high temp powder coated finish and offer superior fit and quality. Our headers are fully welded (no spot welds), and feature a one piece flange for easy fitment.
Fits all 144/170/200ci motors - all models (see details)
See DETAILS for more information and pictures.
Header Coatings:Please Select...Black High Temp Powder Coat Jet-Hot Sterling 2000 (ceramic coating) (+$100.00) Jet-Hot Ford Blue (ceramic coating) (+$120.00)
List Price: $425.00
Price: $315.00
and this:
Home » Ford Six Small » Cylinder Heads » Aluminum Heads
Product ID: FSP-200-ACH
Aluminum Cylinder Head
Details
Our new Aluminum Cylinder Head fits the Ford 170/200/250ci inline six, and comes complete with SI Port Flow stainless steel valves, siliconized bronze valve guides, and hardened seats. Intakes sold seperately.
NOTE: Assembly is required
NOTE: Stock or aftermarket bolts or studs will not work with our new cylinder head, as longer bolts/studs (7 each) are required on the intake side of the cylinder head due to the raised intake ports.
See DETAILS for more information.
Valve size - Exhaust:1.50 diameter
1.55 diameter (+$12.00)
Deposit Paid:None
$50 - deduct (-$54.00)
$250 - deduct (-$254.00)
$500 - deduct (-$504.00)
$1000 - deduct (-$1,004.00)
Price: $1,350.00
Product ID: FSP-250-IMC
Aluminum 2V-4V Intake Manifold
Details
Coming Soon - approximately 11-07
Aluminum 2V-4V Intake Manifold fits our new Aluminum Cylinder Head.
This intake manifold is universal and supports both 2V and 4V carbs with the proper carb adaptor. EFI throttle body adaptor coming soon. Please select the 2V or 4V option when ordering.
Carb Adaptor:2V Carb adaptor
4V Carb adaptor
Price: $285.00
Out of Stock
Old Dec 6, 2007 | 08:06 AM
codeman94's Avatar
Wow...those are pretty cool...but I'm not sure an xpipe will do anything with this kind of application....You can try though...if you are going to do dual exhaust, you may as well make it look cool too!....not sure I'd drop all that $$ for the Cylinder head head though...with both of these mods you might get to....what....150rwhp?
Old Dec 6, 2007 | 06:58 PM
Dougxox's Avatar
I plan ( at least at the moment...LOL) to rebuild the whole engine, heads, cams, pistons, intake, exhaust, rings, bearings etc. preliminary costs are running about $4000. With those heads just out there is still a lot of info to be gained, but hoping to hit between 200 and 250 rwhp and in that light car it should cook.
The nice thing about building up the 6 is virtually no weight gain, as with an 8 not only do you have more engine weight but have to beef up the front end suspension to handle the weight of the bigger engine. this is one reason Shelby got away from the big block 8's because of the weight, reduced speed and handling.
Also the cost is a bit less than droping in an 8 ( or at least the one I want )
Besides I love to be on the cutting edge of something new
BTW there is a guy out there running less than 10 sec in the quarter with a 250ci.
Old Dec 6, 2007 | 09:21 PM
codeman94's Avatar
If an outragous 6 is what you want...go for it....it could be cool!...my 157rwhp in my car is FAST. It feels just as quick as the '04 GT I drove not too long ago.
Old Dec 7, 2007 | 10:42 AM
Knight's Avatar
Needs to be more Astony
that would be a very neat 6 er. with that power you are going to want to get a stronger rearend with limited slip diff.
Old Dec 7, 2007 | 03:23 PM
Dougxox's Avatar
Yeah, I know, have to keep fixing the weakest link with $$$$$$
Just got back from shopping for the little tools and stuff to work on things ( sanding blocks, solvent, primer paint, masking material, etc ) , spent almost $300. Going to order a new radiator in about an hour when I get done bringing in all the stuff Theres another $200. Weatherstriping was delevered yesterday, ordered a new windsheild... My poor credit card
Sep 24, 2015 08:15 PM
billy y
Sep 24, 2015 11:48 AM
jwpraxis
Sep 21, 2015 08:44 PM
Bryanh24
Sep 16, 2015 08:31 PM
Sep 10, 2015 12:44 PM
