What is going on with my car.
Old Sep 1, 2005 | 10:57 AM
KungFuDan's Avatar
Thumbs up
Here is the thing. I brought my 65 out for a drive today and everything was going smooth as far as car running etc... I then get back home and park her in the driveway to do a bit of detailing before pulling it into the garage. When I stsrt her to pull into the garage she starts up but sounds pretty weak and then dies out. I wait 30 secs and try to start up again and there is no response when I turn the key,engine doesn't even turn at all..I'm thinking oh crap what now? So I open up the hood and there is a pretty strong smell of gasoline. I make sure everything is on tight and nothing came loose, wait about 5 min try again, car starts right up. Let it idle about 20 secs and pulls right into the garage as if nothing happened. Any ideas as what happened? Maybe a bit flooded???
Old Sep 1, 2005 | 01:11 PM
BLAKE's Avatar
Sounds like vapor lock. Chances are, your fuel is getting too hot, and trying to go from liquid to gas. Check your fuel lines and make sure they aren't running too close to exhaust, or laying on the block or something like that. I'm not sayin' that's what it is, but the symptoms allow for it.
Good luck.
Old Sep 1, 2005 | 01:21 PM
KungFuDan's Avatar
Thanks Blake
Old Sep 1, 2005 | 04:04 PM
BLAKE's Avatar
Originally posted by KungFuDan@September 1, 2005, 2:24 PM
Thanks Blake
No problemo!
<-crossing fingers that I'm right.
Old Sep 1, 2005 | 08:46 PM
Rickster's Avatar
"try to start up again and there is no response when I turn the key,engine doesn't even turn at all" Vapor lock will starve engine for fuel, you had no crank and smelled fuel, not vapor lock. No crank condition was electrical. Try removing and cleaning the battery cable connections; at the battery, into and out of the starter solenoid, on the starter and also the ground connection on the block. Check the smaller starter wires to the starter solenoid for a good tight connection and clean any corrosion, may want to run a bit of sandpaper over all the contact points.
Old Sep 1, 2005 | 09:23 PM
Big D's Avatar
make sure the car is fully in park too cause last tine we forgot ours in drive and she didnt crank over either...
Old Sep 2, 2005 | 07:54 AM
BLAKE's Avatar
Ooooh, good point. I must've missed that the first time I read through.
Old Sep 2, 2005 | 08:37 AM
KungFuDan's Avatar
I did check all connections. Everything was tight. Can clean em up a bit this weekend when I get some time. Maybe I will post a few new pics of her than too. Put fogs on her and a new wood steering wheel, plus a brand new wax and wash. Thanks for all your help in your responses fellas!
Old Sep 3, 2005 | 11:54 AM
KungFuDan's Avatar
here are some of those pics, with new wash and wax etc....
Old Sep 3, 2005 | 11:55 AM
KungFuDan's Avatar
one more.
Old Sep 4, 2005 | 12:04 AM
future9er24's Avatar
you know, i've never seen that shade of yellow on a early stang.... is it a factory color?
either way
Old Sep 4, 2005 | 12:22 PM
KungFuDan's Avatar
Yeah it is a factory color. It's 98' Chrome Yellow. Painted by the guy who I bought it from last fall. He painted it in spring a few months before I got the car. Originally my car was white with the vinyl top.
Old Sep 4, 2005 | 12:58 PM
well the yellow is definately an improvemnt over white
Old Sep 5, 2005 | 08:03 PM
Coupe's Avatar
Heat soaked starter? :scratch:
Old Sep 6, 2005 | 12:33 PM
Skorch52's Avatar
I had a similar problem: once the car got hot, it was hard to start, if not impossible. Sometimes it would crank weakly, other times not at all. If you pump the accelerator, you get the gas smell.
Turned out to be a weak battery and old battery cables. I replaced them and haven't experienced those symptoms in 3 years.
Old Sep 6, 2005 | 02:12 PM
KungFuDan's Avatar
I think that might be what the problem is. Starts no prob when she first starts, then gets a bit more difficult the more stops and starts I take. I think a new battery and cables are a good idea. Thanks!!!!
Cobiecane
Oct 23, 2015 08:44 AM
Fedupdave42169
Oct 20, 2015 10:29 PM
GLOCKer
Sep 28, 2015 05:20 PM
