tranny troubles
Old May 3, 2005 | 11:09 PM
Jeff900707's Avatar
I've been having a sort of clicking noise i guess you could call it around 1500 rpm. It also occurs at slightly higher RPM's when you give it a little bit of gas. I'm pretty sure it's something in the transmission or possibly the rear end but not quite sure. Any ideas????
I was also looking to fix the problem, if it is the transmission or rear by upgrading some gear ratio's. Right now i believe the rear has 289's but not sure, it has most of it's power top end though. I wanted to balance it out a little more if not lean more to a quick jump of the line. Any suggestions???
Old May 3, 2005 | 11:15 PM
Jeff900707's Avatar
forgot to mention, it's a 351W with a C-6 auto shift kit 2200 stall converter, the rear is a 9" 350 POSI
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
mx5jhb
Sep 30, 2015 04:44 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
Airborne42
Sep 25, 2015 05:14 PM
akdoggie
05-09 Interior and Audio Mods
24
Sep 16, 2015 02:38 PM
