Tail lights stay on when ignition is off...
Old Jul 10, 2006 | 03:36 PM
askdanny's Avatar
...and it's draining my battery.
Tail lights always stay on. One of the two filaments of each bulb always stays illuminated even if car is completely turned off. Everything else works fine.
Any idea?
Thanks.
Old Jul 10, 2006 | 03:53 PM
OKCMustangGT's Avatar
Any idea?
Thanks.
Brake switch?
I had a car do that several years back. It was the little switch the brake pedal engages/disengages. It was broke and the car thought the brakes were on all the time. Inexpensive and easy to check, I would start there if you have not already.
Old Jul 10, 2006 | 06:49 PM
askdanny's Avatar
That's what I thought initially, but then both filaments on each bulb would be on--not just one.
Thanks for your input though.
Old Jul 10, 2006 | 07:52 PM
Lennyb44's Avatar
Number Cruncher
I thought the dual filament lights, the brake switch only illuminated the heavier filament.
Easy way to check is to step on the brake pedal.
If the light gets brighter, then it isn't your brake switch.
Old Jul 10, 2006 | 08:14 PM
askdanny's Avatar
Yeah, I stepped on the brake pedal and the light does get brighter: the heavier filament lights up which is not the one that I have a problem with. So you're right, it can't be the brake switch.
Old Jul 10, 2006 | 09:48 PM
Big D's Avatar
might be ur running lights...check the switch on the dash
Old Jul 11, 2006 | 08:47 AM
askdanny's Avatar
OKCMustangGT, you were right!
I thought it was the running light too, but decided to unplug the brake switch for trouble shooting purposes. And lo and behold, the light went out. So it was a bad break switch. (even if the lights were dim).
Thank you all,
Danny
Chicago, IL
Old Mar 28, 2024 | 07:51 AM
hendog071388@gmail.com's Avatar
I replaced my brake switch 2 weeks ago and now the brake lights won’t cut off.
Old Mar 28, 2024 | 10:41 AM
05stangkc's Avatar
Welcome,
What Year Mustang?
Part Number of Switch Installed?
Either Wrong Switch or Installed Switch Incorrectly.
The Early Switches are a Bit OF Weird.
But Some Further Details Would BE Helpful
Pic of Switch as Installed Would Be Great as Well!
KC
bmarx
May 26, 2020 09:42 AM
Evilmunky
Jul 6, 2018 08:30 PM
2006MustangGT
Oct 18, 2013 09:27 AM
lp9820
May 21, 2008 10:15 PM
Desi
May 23, 2007 07:39 AM
