Brake Lights Problem! Help!
Old Sep 26, 2013 | 10:21 PM
2006MustangGT's Avatar
I have a 2006 Mustang GT that I had just bought from a dealer that has no warranty (130,000 miles) and i've been told that my brake lights arent working properly. According to what I have been told is that only my middle tail lights work when i brake and the outside ones don't work and niether does the third brake light below the spoiler. Every mustang that I have seen has a total of 5 braking lights (except 2010-14) I only have 2...which is weird. I checked my fuses behind the passenger kick panel and even checked the one under the hood and they're all fine. I havent replaced the bulbs but they all seem to be good even though all my tail lights, hazards, and turn signals work. I really need to get this fixed cause I feel out of the ordinary.
Thanks,
Ruben
Old Sep 26, 2013 | 10:38 PM
black-sunshine's Avatar
You need to test the voltage to each light with a mutli-meter. Rent one or borrow it. Check voltage with everything off, then with the brake pedal depressed. This will tell you if the bulbs are getting power. Should be between 12 to 14 volts to each bulb with the brake pedal depressed. If you are not getting power to the bulbs, check your wire harness connections. Also check the voltage at your brake switch on the pedal. That should get you started. Need any more help let me know.
Old Oct 9, 2013 | 02:03 PM
Any luck with your problem?
Old Oct 10, 2013 | 05:20 AM
Lime GT's Avatar
Wonder if you have water damage on the SJB (smart junction box)?
Old Oct 18, 2013 | 09:27 AM
Imatk's Avatar
Did you try replacing the bulbs?
Jim74656
May 1, 2023 02:15 AM
JonsMustang
Aug 10, 2015 05:03 PM
Michael Follett
Jul 24, 2015 06:58 AM
Will3212
Jul 16, 2015 10:30 AM
Kev006
Jul 8, 2015 05:29 AM
