Starter replacement
Old May 25, 2013 | 09:30 PM
dday9's Avatar
Starter replacement
I just replaced my starter on my '78 Mustang II. It has a 4 cylinder engine in it, and my brother thought it'd be easy. Well it took us a whole 3 hours to replace the starter. My problem was getting the darn thing out. The way we took it out was through the top of the engine. My question is, is there some easier way to take it out for next time? Because that was tough getting it out and putting it back in.
Old May 28, 2013 | 02:09 PM
stangs&thangs's Avatar
Do you have a picture of where its located? Not familiar with the mustang 2s but on my 68 it's on the lower end of the car since it bolts to the tranny and all I did was jack up that corner of the car and unbolt everything. Took maybe 10 min
Old May 28, 2013 | 08:14 PM
Juggalo586's Avatar
My starter on my 65 is on the lower end as well. I did it all from the too though, just three bolts and it was out. Really simple.
Old May 28, 2013 | 09:41 PM
Why did it take 3 hours then?
Next time, go from the bottom end. It will be so much easier on you
Old May 28, 2013 | 09:46 PM
This!
10 minutes tops from the bottom. The only thing to do from the top is disconnect it from the battery first.
Old May 29, 2013 | 04:23 AM
Juggalo586's Avatar
Mine didn't take three hours.. It's not my thread lol n
Old May 29, 2013 | 12:19 PM
dday9's Avatar
Yeah, mine is at the bottom probably rear also. What I wound up doing was:
1) Disconnect battery
2) Unbolt starter
3) Yank the starter out from the top
4) Replace
5) Rebolt
6) Hook up battery
There was no way that I could go from the bottom, I'm no mechanic so I don't know what was blocking it directly below it, but the power steering mechanisms where blocking it from taking it out from the bottom/front area. Couldn't take it out bottom rear, because it was bolted onto something. So what I did was unbolt where you pour the transmission fluid and wiggled the starter just enough to where I could yank it out. Putting the new one in wasn't nearly as hard until I had to twist it to where the bolts lined up.
Old May 29, 2013 | 06:10 PM
Haha I didn't even pay attention to who I was replying too
Old May 29, 2013 | 06:11 PM
2) Unbolt starter
4) Replace
5) Rebolt
6) Hook up battery
Do you have a picture from the bottom so you can show is where ur starter is sitting and what's obstructing its path
Old May 30, 2013 | 07:51 AM
dday9's Avatar
Yeah, when I get home I'll crawl under her and take a picture. I don't know how clear it'll show up, but I'll try my best :]
Old May 30, 2013 | 02:12 PM
Sounds good
Old May 30, 2013 | 02:26 PM
HOSS429's Avatar
legacy Tms Member
it probably is much the same as a pinto .. iv`e had some where i had to unbolt the engine .. unbolt the motor and frame mount and unbolt the steering rack and drop it in order to remove the starter ...
lakersfreak
Jun 13, 2022 12:29 AM
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
