Start, then not
Old Sep 15, 2013 | 04:03 PM
ER12883's Avatar
Start, then not
Decided to start up the 67 today, so I charged up the battery, it fired, ran for a few seconds, then sputtered and died. Not too surprised because the carb needs adjusting. I cranked it again and while cranking, everything died. No warning lights, no starter motor, no lights.
Battery has juice. I'll look at fuses tonight after the game. My first instinct is a fuse or a short. Anything else I should be looking at? My DMM is at work so I don't have a way to check voltage or continuity tonight.
67 fastback A code 289 GTA.
Old Sep 16, 2013 | 11:42 AM
dirty/bad battery connection is where I would start! Then check the cables from start to end
Old Sep 16, 2013 | 11:50 AM
ER12883's Avatar
Thanks for the reply! I definitely need to step through from battery on down, but since it died mid-crank, would that point to a fuse or the solenoid?
Evan
Old Sep 16, 2013 | 01:19 PM
HOSS429's Avatar
legacy Tms Member
i would suspect the fuseable link wire .. it is the next big wire that bolts to the starter solenoid with the positive cable .. it supplies all electrical going inside the car .. it can fail and you not know it ..test it with a test lite its full length or simply give it a good pull and see if the rubber cover breaks as the wire may be burnt into inside and it not show ...
Old Sep 16, 2013 | 05:10 PM
ER12883's Avatar
She lives! When I turned the key on this time, the dash light came on, ruling out things like fuses (it's one of them self-fixin problems). But when I went to crank, there was an audible click from the solenoid and all went dead. After checking some things, dash lights came back on, meaning there was most likely a connection issue.
So 10 points for Glenn. I cleaned up the battery terminals and solenoid terminals and tightened down all the connections, and problem solved! Thanks guys!
Evan
Old Sep 16, 2013 | 06:50 PM
woot what day is it
Old Sep 16, 2013 | 07:49 PM
ER12883's Avatar
Originally Posted by Glenn
woot what day is it
What day?
09-gt/cs
Oct 15, 2015 10:03 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
GLOCKer
Sep 28, 2015 05:20 PM
