Sick engine noise
Old Jan 21, 2007 | 06:25 PM
Harley's Avatar
Sick engine noise
I've been out of town a while and during that time a family member drove my 69 (351W). I get home and start the car and immediately hear a loud tick-tick-ticking sound that speeds up with the engine rpms. Sounds like it's coming from under the driver's side valve cover.
Any theories as to what I'm dealing with and how I might go about checking it out? Stuck lifter? Worse? It's not a loud clunking sound, but more of a higher pitched ticking.
Old Jan 21, 2007 | 06:41 PM
Lennyb44's Avatar
Number Cruncher
Sounds like a stuck lifter to me.
Or maybe just an adjuster that's backed off the pushrod somewhat.
My 69's shop manual had a nice step by step for adjusting valves.
Unfortunately the manual went with the car when I sold it.
As I recall, it wasn't real difficult, just a little messy.
Try googling "351W valve adjustment".
Old Jan 26, 2007 | 09:01 PM
Harley's Avatar
You're right, it was a rocerk arm adjuster that backed off. I tightened it down and that ended the ticking noise ... temporarily. I just took it for a long test drive and I'm hearing it again (although not as loud). Can those adjuster nuts wear out, or is this a sign of a more serious problem?
Old Jan 26, 2007 | 09:45 PM
codeman94's Avatar
I thought exhaust leak right away.......maybe you have that too.
Old Jan 26, 2007 | 10:10 PM
Harley's Avatar
I'll check for the exhaust leak. It was obvious when I unbuttoned the valve cover that a rocker arm nut had really loosened up. When I tightened it, the noise went completely away, only to come back faintly after I drove it about 30 minutes. I haven't had a chance to give a close look at it again.
Old Jan 26, 2007 | 10:47 PM
Rapture's Avatar
On my 72 351C Gran Torino sport.............. The ticking was from the exhaust manifold on both of them.
Edit: OMG I would love to have just one of them now
Old Jan 26, 2007 | 11:20 PM
Lennyb44's Avatar
Number Cruncher
They wear out.
On my '69, I replaced all of them.
(Probably could have got away with just replacing the (2) that kept backing off, but I got tired of pulling the valve covers off.)
Back in the '90s, a set of (16) rocker nuts ran about $20.00
If you can't find them at a parts place, most good engine rebuild shops have them. Take one of the old nuts with you to make sure the threads match on the replacements.
Old Feb 3, 2007 | 02:31 PM
pakrat's Avatar
It may be worn but are you just tightening it or are you torqueing it to specs properly?
Old Feb 4, 2007 | 10:00 AM
ravenblack67's Avatar
I went through a long and painful diagnosis recently. Try removing the spark plug wires one at a time. If the noise goes away, it may be connecting rod bearing or exhaust manifold gasket. If the noise remains, it may be a lifter.
Old Feb 5, 2007 | 02:30 PM
Knight's Avatar
Needs to be more Astony
my 1990 did that to me. rocker nut fell off twice... i used lock tight on it and it was fine after that.
here is a picture of my wonderful journeys in the valve cover to fix the darn thing.
Old Feb 7, 2007 | 06:02 PM
Lennyb44's Avatar
Number Cruncher
Wow!
Those are some pretty rocker arms.
My '69 had the old cast ball type.
Old Feb 7, 2007 | 07:43 PM
Knight's Avatar
competition cams roller rockers. don't remember the specs
Old Feb 8, 2007 | 01:45 PM
codeman94's Avatar
I have the same ones!...but they are blue!
Old Feb 8, 2007 | 01:57 PM
Knight's Avatar
I beleive the red and blue ones are different specs.
actually i checked comp cams sight and i couldn't tell, maybe they just offer them in different colors...which seems weird to me cause no one can see inside anyway i would think they would use different color to help differentiate specifications.
Old Feb 8, 2007 | 02:30 PM
codeman94's Avatar
yeah...different colors would not make sense just for the sake of having different colors...
Road_Runner
Sep 2, 2024 04:46 PM
Uofmrampage
Aug 2, 2022 02:55 PM
Mr. V
Dec 24, 2016 02:57 PM
Rando
Sep 30, 2015 12:28 PM
