running hot
Old Jul 13, 2006 | 05:41 PM
big_block's Avatar
running hot
hey guys i bought a new 3 core rad and fan and hroud and installed it and i am still running hot sitting still i saw 200 deg with a 180 stat in what the deal what do i need to do i went with a 5 blade fan also steel do i need to set the timming different to lower the heat ? its a new water pump too maybe 1 to 2 years old the stuff i bout was org to 65 mustang also can someone help me run cooler ???
Old Jul 13, 2006 | 08:49 PM
codeman94's Avatar
Thermostat?....I dont know...maybe your gauge is wrong? How long does it take to heat up?...Cause with mine, it takes a long time to even get it up to normal...she's cold natured...
Old Jul 14, 2006 | 03:20 AM
big_block's Avatar
it heats up normal the gauge shows 170 sitting ther ideling so it might be off 10 deg but in the wrong way if it shows 200 it is 210 i guess right cause it reads 10 deg low i don't know what the deal is mabe i go with a 160 and see ??
Old Jul 15, 2006 | 07:13 PM
big_block's Avatar
ok i did a adjustment on timming and its about 1 1/2 in above the mark is that right ???? its a little cooler but still at 200 at red lights witha 180 stat in ??? what do you think
Road_Runner
Sep 2, 2024 04:46 PM
RCooke08GT
Feb 19, 2017 03:03 AM
Sep 30, 2015 07:02 PM
