The rear sags
Old Apr 18, 2012 | 06:14 PM
rd127a's Avatar
The rear sags
I have 1968 Coupe and the rear seems to squat down . anybody got suggestions how to get it up, like maybe heavier springs . Any suggestions will be helpful
Old Apr 18, 2012 | 06:16 PM
11SHELBYGT500's Avatar
New leaf springs
Old Apr 18, 2012 | 06:35 PM
dmay65's Avatar
New leafs but that raises the question what type of ride height do you want and what type of ride do you want
Old Apr 18, 2012 | 07:31 PM
houtex's Avatar
Air shocks, or air bag suspension helpers, or air bag suspension outright could also be done... although the latter is likely stupid expensive...
I went with the air shocks, and that worked well on Muskrat.
Old Apr 18, 2012 | 10:41 PM
dmay65's Avatar
Yea but air shocks come with risk. If you can fork out the 200 for leafs and 100 for new gas a justs you will be much better off
Old Apr 19, 2012 | 08:39 PM
houtex's Avatar
Um... Ok, I'll bite.
What risks? I'm curious and ignorant, and lazy to boot, as I'd rather you tell me than do a google search.
/Muskrat never had a problem wif 'em...
Old Apr 19, 2012 | 09:40 PM
dmay65's Avatar
A lot of people run them as it is an easy option to put the car at the height you want but the shock mount points on the body are right under the seat or right behind. Not the thickest metal, and definitely not meant to hold the weight of the entire back half of the car. Just meant to slow abrupt jolts. When you put air shocks on and fill them with air what your doing is taking all the stress off the springs ( which are mounting on the frame not shell) and putting all the weight on those shock mount points( which are on the thin body metal). A friend of mine was running them for a while and one day hit a pot hole and it shoved the shock threw his floor into his cab. Doesnt happen to everyone but if your going to run them just know the risk so you can beat yourself up when it happens lol. ))
Old Apr 20, 2012 | 02:34 PM
Paris MkVI's Avatar
Originally Posted by dmay65
If you can fork out the 200 for leafs and 100 for new gas adjusts you will be much better off
+1. Did this on my '69 many years ago. Definitely the way to go.
Old Apr 20, 2012 | 07:13 PM
houtex's Avatar
Ah. Well there ya go. Good info!
/I am a little more knowledgeable. Did not know that, now I do!
Old Apr 21, 2012 | 04:16 PM
rd127a's Avatar
I would like to get the car so it looks level or a little higher in the rear. I figured I would need new leaf springs but wasn't sure if, to go with stock or a heavier set Are the gas adjust different types or are they all the same . I am not sure what to look for when buying a set . Thanks for the info on air shocks . I was considering them but not now.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 16, 2015 06:44 PM
