Radiator advice
Old May 12, 2012 | 05:46 PM
Luis69stang's Avatar
Radiator advice
Hi everyone, I have a 69 with a 302 auto.... It sometimes overheats and I am pretty sure it is because of it needs a bigger radiator
Currently has a 2 row, 20" width... Would a aluminum 3 row, 24" width be enough?
Old May 13, 2012 | 01:46 PM
drumr90's Avatar
I would say it would be good. I swapped out my 2 row for a factory 3 row for same problem.
I would check ur thermostat first before changin radiator.
Old May 14, 2012 | 09:31 AM
FMSixtySeven's Avatar
Radiator Hoses
Also check the radiator hoses to see if they are collapsed. If they are not, run the engine and see if they collapse at higher or lower rpms. If they do, then replace the hoses with a support spring inside to keep it from happening again.
Ben Garland
Cobiecane
Oct 23, 2015 08:44 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
GMAYS
Sep 10, 2015 06:19 AM
