Question
Old Apr 6, 2013 | 01:23 PM
64mustang's Avatar
Smile Question
I have a 64.5 Mustang 289 cid. D motor. What is the torque Specs for Intake manifold and timing settings? What is step one ft lbs of torque, second, and last?
Old Apr 6, 2013 | 07:44 PM
FMSixtySeven's Avatar
There should be torque specs on specific engine bolts in the Mustang shop manual. I know the intake manifold torque specs are in there.
Old Apr 7, 2013 | 05:37 PM
64mustang's Avatar
Unhappy Answer
I don't have a shop manual
Old Apr 8, 2013 | 10:34 AM
HOSS429's Avatar
legacy Tms Member
there are as many ways to torque the intake as there are intakes out there .. google search shows many .. i just put the thing on and tighten it down .. google says start at 5 ft lbs and go up to 20 in 5 increments then wait a day and final torque to 22 ft lbs .. skip around from side to side to get equal crushing effect .. i dont know about the timing .. i raise mine till it pings then back off till it quits ...
Old Apr 8, 2013 | 04:33 PM
matcox83's Avatar
I only have the 66 specs, but surely the same. If you plan to do stuff like intakes, you should probably invest in a manual. This one is $30 from CJ Pony Parts.
http://www.cjponyparts.com/shop-manu...4-1973/p/BKS0/
Here's the order and spec for 66. First step 15-17, then 20-22.
Old Apr 13, 2013 | 09:26 PM
64mustang's Avatar
I think I install my new heater cable wrong. Now lever up have heat, lever down no heat. How can I fix it because I can't find it on google or Bing search?
Old Apr 16, 2013 | 03:40 PM
64mustang's Avatar
How do I adjust my heater cable so lever is down have heat
Old Apr 17, 2013 | 08:36 AM
matcox83's Avatar
Shouldn't be hard. Start a new thread.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
