Power steering question
Old Dec 29, 2005 | 05:27 PM
bullittman68's Avatar
I just finished replacing the PS control valve and also the steering box. I figured the control valve would fix it but it still does not come back to center. When you finish making a turn, the wheels keep pulling to that direction and barely move back towards the center at all.
I figured that this was a problem with the alignment now. Do you think that's right? who knows about this or has had this problem?
thanks ahead of time
Old Dec 29, 2005 | 05:51 PM
also the steering wheel is off center now. does the alignment fix that? do I need tell them to adjust the tie rods to fix that when I take it in?
thanks
Old Dec 30, 2005 | 08:07 PM
no one? I know someone has an answer.....
Old Dec 31, 2005 | 05:28 PM
codeman94's Avatar
sorry...The only thing I know about power steering is that it is ridiculously better than manual steering. Hope someone helps you out.
Old Jan 9, 2006 | 08:44 AM
gjz30075's Avatar
Does it not return to center from either direction? If so, its probably a castor problem and an alignment should fix it. If not, it could be that you have the hoses on the PS valve reversed.
iliveonnitro
Oct 7, 2021 06:31 PM
Automagically
2012-2013 BOSS 302
37
Feb 19, 2020 09:28 PM
JonathonK
Sep 24, 2015 06:31 PM
Linkspure
Sep 12, 2015 06:33 PM
