Oil pan ?
Ok just a few hours go I was lowing my car down and the jack slip out and put a hole in My new oil can u remove the oil pan inside the car or do I have to remove the motor
Several months ago I had to replace the rear main seal on the V8 in my 1967 coupe - which, of course, meant removing the oil pan. The only additional part that I needed to remove to get it out was the underbody cross-brace (2 bolts). Good luck on your fix!
I also highly recommend replacing the pan gasket with the new Fel-Pro one-piece rubber gasket. It really makes reassembly ultra-simple!
http://www.summitracing.com/parts/FEL-OS34508R/
