Oil pan ?
Old Nov 12, 2011 | 06:01 PM
mustang-68's Avatar
Ok just a few hours go I was lowing my car down and the jack slip out and put a hole in My new oil can u remove the oil pan inside the car or do I have to remove the motor
Old Nov 12, 2011 | 06:04 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
If I'm right you can lift the motor a few inches by taking the mounts loose and that gives you enough room to take it out. I'm not sure though.
Old Nov 22, 2011 | 01:54 PM
ChrisM's Avatar
Several months ago I had to replace the rear main seal on the V8 in my 1967 coupe - which, of course, meant removing the oil pan. The only additional part that I needed to remove to get it out was the underbody cross-brace (2 bolts). Good luck on your fix!
I also highly recommend replacing the pan gasket with the new Fel-Pro one-piece rubber gasket. It really makes reassembly ultra-simple!
http://www.summitracing.com/parts/FEL-OS34508R/
Old Nov 23, 2011 | 11:08 PM
mustang-68's Avatar
Do I still need to pick up the motor
Old Nov 29, 2011 | 10:19 AM
ChrisM's Avatar
Nope.
dblhelx
Oct 6, 2015 08:08 PM
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
