Oil
Old Apr 23, 2006 | 01:14 PM
Justin's Avatar
Which oil does anyone reccomend? I have a 1968 Fastback, is 10W-30 alright?
Old Apr 23, 2006 | 01:34 PM
codeman94's Avatar
I use it....Castrol Syntec... for my 289....if you have a motor with some serious ***** (400-500hp), you might want something a little heavier...
Old Apr 23, 2006 | 02:52 PM
Justin's Avatar
My engine is stock-ish so probably puts out about 230hp, small block 4 barrel, what about Motorcraft 10W-30
Old Apr 24, 2006 | 07:22 PM
66 stang's Avatar
castrol
Old Apr 26, 2006 | 10:43 AM
ugly74's Avatar
I use Mobil 1 10-30 in everything I drive.
as far as the oils weight goes, it all comes down to what kind of bearing clearances you're got.
watch your pressure gauge...
if it's real high all the time, you can probably drop down a grade.
if it's drops a bunch once it's warm, you should run a bit heavier.
$.02
Old Apr 26, 2006 | 03:01 PM
Justin's Avatar
This is the one I will use, my Dad's a mechanic and he says this is what I should use
http://putfile.com/pic.php?pic=4/11316225654.jpg&s=x402
http://putfile.com/pic.php?pic=4/11316232351.jpg&s=x402
http://putfile.com/pic.php?pic=4/11316235787.jpg&s=x402
http://putfile.com/pic.php?pic=4/11316241782.jpg&s=x402
http://putfile.com/pic.php?pic=4/11316251657.jpg&s=x402
http://putfile.com/pic.php?pic=4/11316264533.jpg&s=x402
http://putfile.com/pic.php?pic=4/11316272278.jpg&s=x402
http://putfile.com/pic.php?pic=4/11316281963.jpg&s=x402
Old Apr 26, 2006 | 05:42 PM
66 stang's Avatar
whyed you host the same pic 8 times?
Old Apr 27, 2006 | 02:39 AM
Justin's Avatar
All the pictures are different
Old May 2, 2006 | 08:52 AM
Skorch52's Avatar
What's a quart of that cost? If you are going to pay a premium, might as well get a premium synthetic oil. I also use Mobil 1 in both my Mustangs (10w-30 in the 66, 5w-30 in the 98). It costs a little more, but I change it every 7500 miles so I get my money's worth. The 98 has used it since the first oil change at 1500 miles and absolutely no problems.
Old May 3, 2006 | 12:48 PM
Justin's Avatar
I was told not to use synthetic in classics?
Old May 3, 2006 | 03:29 PM
codeman94's Avatar
why not?....
Old May 4, 2006 | 05:34 AM
Justin's Avatar
Don't know, I read it on several forums
Old May 4, 2006 | 06:15 AM
Skorch52's Avatar
I think that's because older engines tend to leak more, and if there are any leaks, the synthetic will find them. But the quality of the synthetic oil is better than non-synthetic regardless of the engine size or age. Just remember not to mix it - if you're using regular and going to synthetic, replace it all.
Old May 4, 2006 | 07:49 AM
Justin's Avatar
No I won't, i'll stick with the above
dblhelx
Oct 6, 2015 08:08 PM
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
